G5 Freezing on Talkgroup
fmulder13
Minneapolis, MN
My G5 is doing something I never saw it do pre-firmware 1.2. It's hanging on a talk group after the transmission is complete, and not passing audio from that talk group or any other talk group. It's basically frozen for a bit. It then goes back to the main screen, loses the control channel, regains the control channel, and then goes about scanning normally. It's done this 6 times in the past 20 minutes. It only seems to do this when connected to bluetooth.
fmulder13
Minneapolis, MN
That's my go-to fix. It then returns to business as usual for a while, until it descends into the same problem again.
Jordan_yeh
Unication Representative
Taipei
The trunked system can tell device stay on this TG and traffic channel for wait for coming voice message a while , this is efficiently to have traffic capability, it is ok, if you feel uncomfortable, you can send me your log file to my server , we can do analysis on the air signaling and device processing
K5TXC
Bedford, TX
I had a problem with the G5 not passing audio on a channel that was marked to record, it seemed liked it would hang on that channel also. I unchecked the "record" box in the PPS software and haven't had a problem since.
Tylerv21
Greetings!
Thought I would piggyback on your thread fmulder. I have the same issue concurring on 1.2 - however not all G5s I deployed into the field have the same condition.
I tried everything including a whole new PPS file from scratch and going through each setting by hand. Had some help from a vendor and tried some things to see if it would help - no luck.
I reverted back to v1.10 and have had a pager running this for almost a week now - no issues other than a weird error that vanished on me when I turned the pager off and back on again.
I have to have the record option available for the responders - they require/like the ability to play back pages for addresses and such. I can't think of anything else to try for v1.2 so I will probably deploy this new batch of pagers to the field with v1.10 and hope the next firmware release fixes this problem.
Have you had any further issues or have you found a workaround for 1.2 that works for you fmulder?
Thanks!
T
fmulder13
Minneapolis, MN
T,
I've found it happens much less with different Bluetooth devices. I've gone to using the Mpow Crescent, the JustWireless headset from Walgreens, and the Tenergy Beanie. All of these devices exhibit this problem on a very rare basis, so I've sort of learned to live with it. I'd love to see an ultimate fix, though. The Mpow is running bluetooth 4.2 with EDR, and the others are bluetooth 4.1. The Galaxy Buds appear to be bluetooth 5.0.
Does your issue happen off bluetooth? Mine only happens when connected to bluetooth. I'm hesitant to revert to 1.10 for fear of the beeps before transmissions on bluetooth.
Greetings!
Thanks!
T
picscan
CA
My G5 froze for the second time last night, did it last week too, wouldn't turn off, wouldn't respond to anything, I didn't notice for hours and was wondering why police were so quiet. Pulled the battery and it's okay now. I had been using bluetooth earlier in the day. Is that what's causing it?
fmulder13
Minneapolis, MN
What firmware do you have installed?
fmulder13
Minneapolis, MN
This sounds like a problem I had occasionally with V 1.10. V 1.20 has fixed any freezing while not on bluetooth, save for what I mentioned at the beginning of the thread. I remember the battery pull being the only solution to your problem. I don't believe bluetooth had anything to do with it.
Tylerv21
T,
The reset/freeze issue was happening with Bluetooth completely turned off.
I've had no freezes/resets with 1.10 since I reverted. I'm not using the Bluetooth so I understand the feeling to stick it out on 1.2 until it's fixed - I wouldn't be able to withstand the beeping issue!
I have 5 mission critical G5s to program - I've been sitting on them due to this problem. A vendor we use looked at my files - everything checks out.
Guess I'll deploy with 1.10 with a heads up on that weird error that asks for a reset. Hoping we see a new firmware update in the coming months - if it fixes this freezing issue.
T
