G5 quick programming question
beerad4
Springfield
Greetings!
Is it possible to put numerous counties sites on one knob position? If so how would I do it?
Thank you!
N6ML
It depends. If they are all sites within one P25 trunked system, you can (but you may not want to). If they're all conventional systems, you can create a knob position that scans them. If they span multiple trunked systems, or a mix of trunked and conventional, you cannot (at least with the current firmware).
bob550
Albany County, NY
While it's theoretically possible to put multiple sites in one knob/zone position, the G5 will lock on to and hold on the strongest site while disabling the reception of the other, weaker sites. Now, if you were doing this with the intention of using the G5 while roaming among the programmed counties, then this programming convention may work. Even in that case though, the most sensible thing to do is to split sites and counties among multiple knob positions as Unication recommends, and switch as needed.
