I am interested in building a gable end antenna and would appreciate any information or advice.View attachment 171398
Ok thanks. I’m going to build one first for fun, but if it doesn’t work out and I smell smoke, then…..11 meter / 27 mhz 1/2 Wave Dipole Antenna for CB Radio 2KW ICAS | eBay
Rated for 2kw ICAS. The 1/2 wave dipole is a balanced antenna that needs no balun, has less RFI problems than an end fed half wave. Can be installed as an inverted vee, dipole, or a vertical. Each antenna is individually tuned slightly below the bottom of the band so you can tune to your...www.ebay.com
I do recommend running a 1:1 balun instead of the coax going direct to the antenna.Ok thanks. I’m going to build one first for fun, but if it doesn’t work out and I smell smoke, then…..
I thought I’d just run the wires along the bottom outside of the gable ends which would give me an inverted v dipole.Gable mounts all kind of depend on what kind of antenna you want to run. If you want to put up a big vertical there then I'd say think twice. Gable mounts aren't really able to hold heavy antennas or high wind loads. They attach to the soffit boards and those are literally just nailed on, so a good wind can just pull the whole thing off. For a heavy antenna a mast braced against the house is better, or a small tower. If you want to use a dipole on a short mast then a gable mount made from unistrut and pole straps will hold it pretty well.
Yes, that should work but it’s better if you space the wire at least a few inches out from the gable and shingles. Wire right up against the wood or shingles will usually interact with the structure and may want to be a little shorter than calculated. Electric fence insulators are around 4” long and are a cheap way to space the wire from the structure.I thought I’d just run the wires along the bottom outside of the gable ends which would give me an inverted v dipole.
Ok thank you. I’ll do just that. How far away from any metal objects should the antenna be? There’s no flashing on the front, but there is some at the back of the house in case I decide to put another one there.Yes, that should work but it’s better if you space the wire at least a few inches out from the gable and shingles. Wire right up against the wood or shingles will usually interact with the structure and may want to be a little shorter than calculated. Electric fence insulators are around 4” long and are a cheap way to space the wire from the structure.
Lengths of metal like 6ft or less should be ok a few feet away. Longer maybe 20ft away. Short ones may affect tuning a little but wont affect radiation pattern. Longer lengths close by can make the antenna directional.Ok thank you. I’ll do just that. How far away from any metal objects should the antenna be? There’s no flashing on the front, but there is some at the back of the house in case I decide to put another one there.
It's doubtful you'll let any magic smoke out. One antenna wire connects to the coax center conductor, the other wire hooks to the coax shield. Just be sure no wayward strands from the shield contact the center conductor.Ok thanks. I’m going to build one first for fun, but if it doesn’t work out and I smell smoke, then…..
How far above do you recommend?There is almost always a metal flashing on the edge under the shingles. Keeping above that would really help.
