Galaxy saturn 11 meter
N1EXA
FT8 Huntin Mudd Duck on the deep end of the pond !
Acushnet Heights New Bedford MA - GRID FN41 mp
Ok i also forgot to mention! When you first turn on the power lever and the meters light up and thats it then when you click by turning the squelch knob thats when the freq counter and the rest of the radio lights up! Im guessing this is not nornal! I guess its just one more thing im gonna have to explore!
Just leave the squelching at the 1 or 2 position basically around 8 to 9 O'clock
And only use it at a higher level if needed.
There us no need to leave the C B in
P A mode.
Pete N1EXA
109base
10-9 base
Yea i was just wondering if it was normal to have to turn the squelch on to get the frequency counter to light up or get power?
109base
10-9 base
The radio is a older galaxy Saturn i think from 1990. Defiantly one of the first generation radios.
109base
10-9 base
In doing my trouble shooting i came across something that stopped me and now i have to figure this out! Ok im getting normal voltage aprox 14volts to the power switch! But when i turn it on the voltage drops to 7 volts! I dont think that is normal.
109base
10-9 base
Ok i think i have figured this out! Im waiting on some parts to replace and after im done i will explain what i found! I appreciate everyone’s feedback! Very interesting findings!
109base
10-9 base
well im making progress on my galaxy! The biggest thing is finding the right parts! I got the receive to work now and rebuilt the all board that is just before the power supply! It had some bad caps on it! Replaced a few transistors now I'm having to rebuild the freq control board! Thats i think where my transmitter problem is.
109base
10-9 base
well im still working at it! I bought another identical working galaxy saturn to use as a reference they are only 1 year apart in age so should be pretty close! Its a big help in trying to restore solder traces and a few other things!
109base
10-9 base
Well just a update im still working on my galaxy saturn radio! What a radio to learn on! Ha! The biggest challange is finding new parts and not having to order directly from china! Trying to buy name brand nos parts is kinda tough at times but im getting it done! Im
Hoping for good news soon as it seems i take 1 step forward and 2 steps back working on things but im learning ! Stay tuned ill bring updates soon!
tramd
One thing to know is that parts were many times added to the bottom and even the top side of circuit boards by the engineers. They were making improvements or correcting issues that arouse. They couldn't redo the artwork and have new boards produced due to monetary issues so they had to use what they had. Many boards will have disc caps, resistors, diodes, jumpers, cut traces, etc. added to the boards. These are factory mods. I've seen many times when people have removed these, thinking they were added by someone and then rendered the radio inoperable or reduced its operability. The schematic often times did not show these factory mods, as only the original was released and revisions weren't. Sometimes the only way to know if they are factory mods is by examining the soldering. Do all the parts added look like they were all soldered by the same person? Many times you have to search for pictures or videos and hope to find a pic of the board to see if it has the same parts added. It may or may not, depending on when it was made. Usually the later ones will have the most parts added. I once had three Navaho 458s I was repairing at the same time, and every one had a different amount of disc caps on the bottom. They only made that version with the 858PLL for two years. The one with the lowest serial number had the least amount of caps, and the highest had the most. Since all the circuitry was identical, just caps added to the bottom for improvements, I add the extra caps to the earlier two so they would have all the improvements.
109base
10-9 base
Yes i learned that the hard way if you look back at my early post i showed a pic of the board cause i too was confused someone that saw it said it did not look factory so i took it all off! Big mistake! I now know know! Anyway i bought a second radio i have been using for comparison and am in the process of putting it all back the way it is suppsed to be! I got parts coming today hopefully ill be able to see progress! Today.
