N1EXA
FT8 Huntin Mudd Duck on the deep end of the pond !
- Joined
- Mar 3, 2022
- Messages
- 324
- Reaction score
- 320
What you need to work on this radio is an old school Heatkit Tube Voltmeter and a home brew RF probe.
What happens with these radios is guys want more power but the radio is only designed for 10 watts AM say 20 SSB
and if you go to page 29 in the manual you will see C166 (560pf) off the Final amp - Those vaporise over time and high power
so you have to put a higher voltage on or take 2 -330pg and parrellel them up to handle the stress.
I seen so many cbers swap finals and say it does not work. thats where the tube voltmeter and probe come in. you cant trouble shoot
stuff with a Chinese DVM other than basic AC line power DC Voltages and Current and resitsors removed from the circuit.
I had to put a bigger transistor on the 8 v TX switch and the Transistor feeding the voltage to the Finals too.
There is a page on the web that i cant find now but shows the 2 ceramic caps that are added to the finals for tuning.
Bottom of the Circuit Board ! ( Look )
Hope fully the original tech put them back where they were. Its best to take pictures before unsoldering anything because you may find
out that it was OEM work at the factory and not the golden screw driver.
Pete N1EXA
Pete N1EXA
