Garland County
Toocool
Mt Ida, AR
Does any one have a list of the Police/Fire frequencys? I have checked the database but am having trouble with the police and fire Tach 1.
Thanks.
pappy1
Central Arkansas
City of Hot Springs: 800 Trunked
Hot Sprngs 855.48750 MOT 0.0
Hot Sprngs 855.98750 MOT 0.0
Hot Sprngs 857.43750 MOT 0.0
Hot Sprngs 858.43750 MOT 0.0
Hot Sprngs 859.43750 MOT 0.0
Hot Sprngs 860.26250 MOT 0.0
TGID:
Dispatch 00016
Channel: 2 00048
Tac 1 00240
Tac 2 00848
Operations 00912
I hope this is what you wanted.
Toocool
Mt Ida, AR
Garland Co
I have programmed the frequencys using WIN 87 posted by pappy1 but I am not sure it is working correctly. I am picking up traffic but I think it is simply scanning the frequencys. It does not display the TGID when it stops on a frequency. Any ideas?
KE5BCP
Analog Man
Lewisville, Texas
Make sure each channel is set to MOT.
Make sure the bank is set to MOT.
Toocool
Mt Ida, AR
There is one place in WIN 97 for the type and it is set to MOT. When I arrived in HS today the scanner stopped on 859.4375 and it sounded like low freq FSK. Sounded like a motor running in burst. I finally had to lock out that channel to enable the scanner to sweep. ???
KE5BCP
Analog Man
Lewisville, Texas
The "type" is for the entire bank. You MUST set each channel's "Rx Mode" to MOT as well in order for proper trunk-tracking (see pic).
Toocool
Mt Ida, AR
I did not have that set correctly, next time in town I'll see how it works.
Thanks W5JSS
bpckty1
I don't have them. I was hoping you, or someone on the list from Hot Springs, have a current list.
bpckty1
I did, but sometimes those that live nearby have freqs that are not on the DB since they are intermittent and have not been submitted since they are not completely verified. I have a couple of freqs from where I live, but since they "pop-up" only every month or so, they remain in my questionable/unverified bank in one of my scanners.
INDY72
Indianapolis, IN
Thanks for the new updates for Hot Springs area! I just won 2 PRO-92's on ebay and was gonna prog one for my Mother in HS.., shipping the other to an friend in NM, in another area we badly need verification of freq's and usage in fact! This makes it easier now that I have verified info on the new HSFD stuff! As far as the National Forests/National Parks: If you have older wideband FM freqs, I'd not trust them, as most NPS/USFS is in the process of changing over to narrow FM, and a lot are going digital with encrypted LE ops! Anyone in the area needs to do an dedicated search in the following bands: 138.0000-143.9875, 148.0000-150.0000, 162.6000-173.9875 MHz... If you have an digital capable scanner, that will be helpful.
