Gateway?
W5JG
Since this involves two different systems, I'll post here, in the generic trunking forum. I'm not the one who will be implementing the solution, but I'm looking to see if there is a better way to do this.
Here is the scenario: A Harris P25 system and a Motorola TRBO system across town. Have four existing talkgroups on the Harris side gatewayed to four new talkgroups on the TRBO side.
The obvious method would involve using four TRBO radios connected to the Harris interop gateway, with analog audio in/out of the interop gateway.
Is there a way to connect the two systems via IP and eliminate the four TRBO radios and the analog conversion? Obviously, this would require something that can speak the TRBO protocol and also talk to the Harris interop gateway. Does such a thing exist?
Thanks.
Firebuff880
Boynton Beach, FL
Thanks.
Avtec Consoles and Twisted-Pair (Now a Division of Motorola) are the only two suppliers with a license for IP Audio into MOTOTRBO. So the short answer to your question is no. Control Stations are your only answer.right now.
But depending on the topology chosen for the MOTOTRBO(tm) deployment there may be a few other answers. AKA: IP Site Connect, you could talk with Rayfield.
Pure VoIP Dispatch for Mission-Critical & Operations
WAVE 3000 - Motorola Solutions USA - Motorola Solutions Australia & New Zealand
c-Bridge
JRayfield
Springfield, MO
We are also licensed for the audio interface at the IP level for conventional MOTOTRBO systems (single repeaters or IP Site Connect systems). The c-Bridge is the product that can do this.
John Rayfield, Jr.
Rayfield Communications
c-Bridge
