Hopefully this is an appropriate place for this. Basically this is just a bunch of stuff I haven't been able to understand. My knowledge of this field with radio/frequencies is limited to the FCC Technician License as well as basic researching with help from people here helping me to find a vehicle mount/scanner setup. So very basic ground-level knowledge. I personally use a scanner setup (SDS-100).
Also for all of these, genuinely anything would help, like if you say absolutely nothing and just post a link and be like "figure it out" I will 100% do that lol. I don't expect essay level replies although I don't mind reading, I'd appreciate even just a general push in the right direction, I have no problem studying/researching, just don't really know where to look for some of this.
So for these questions:
1. I see TGIDs but no individual frequencies listed in various software. From what I understand, TGIDs are a lot of frequencies or units, all interacting together. So if Fire 1, Fire 2, and Fire 3 are all operating within one area, I suppose TGIDs are used to make categorizing groups easier? I guess I don't understand the point? Is it just to say "Ok this group of people, these units, are using these frequencies, and they're all part of a group".
2. As I mentioned, I see sometimes TGIDs are listed without frequencies individually. I'm guessing that one way to separate it and figure it out is by listening to a programmed TGID, and paying attention to which frequency is used, and making note of it.
3. I noticed some units or frequencies have different frequencies, which is confusing to me. Like Tone A and Tone B and they'll be assigned supposedly to the same emission source, but why are they two different frequencies, and why Tone A and B, and what are the "tones" supposed to mean.
Example: Medic 1 - Ambulance Tone A > 584.8 Hz Tone B > 651.9 Hz . I also see "Fire Tone Out". I've not done a lot of research into this, maybe it's related?
4. As well as, along this area of topic, I see that different transmissions have a VHF frequency, and then a UHF frequency. I see it a lot with aircraft communications. Why two? The only explanation I can think of, is so different receivers can hear. Not sure.
5. Next is encryption. Very confusing for me. From my area (Okaloosa County, Florida), FHP, Fish and Wildlife, some select departments, and some select Emergency Services, are labelled "DE". L, unlucky. But I've also seen people say "You can't listen to SLERS". However, I see people claim "Here's the SLERS frequencies" and it works. And then there's EDACS, Provoice, DMR. So Statewide Law Enforcement System. So SLERS is NOT an encryption, rather, a system right? Which means Provoice, EDACS, DMR, are all separate encryptions?
6. Also I've successfully found and listened to channels from like 100-300-700. However, when it comes to 850+, I have many many many programmed, but never hear anything. I'm wondering if maybe these are the sets of encrypted channels as I beehive I was told these are common for "public safety" and such. But as far as I know, higher frequencies have shorter waves, which means less range right? So maybe these radios are out of range? My SDS-100 should be able to detect those though. As well as, even if I can't listen to encrypted channels, I'm guessing the radio will still pick them up, it'll just sound like static. (For reference I do have DMR/Provoice unlocking)
7. Next I learned that repeaters can be linked or in a system. How far can repeaters carry a signal. And is there degradation over distance, time. As well as, is there a max distance for repeaters? Can I talk to someone in a different state without a proper antenna setup worth hundreds/thousands etc. Like imagine I'm only able to head near a repeater, and use a simple transmitting-capable handheld. As long as I can get that signal to that repeater, I can send it along the series until it reaches the person right?
8. Additional sub-question, would it be possible to use sky-wave to bounce an HF signal off the ionosphere to a repeater and have the repeater carry to a station. This would eliminate the need for multiple repeaters right? Or maybe using a satellite for uplink and downlink. Seems like there's multiple ways to send a message to someone in this hobby. "Multiple ways to skin a cat" as they say?
So yeah, that's pretty much the questions I have that I don't really know where to look to learn or understand. Anything is appreciated.
