Generic or proprietary cable?
n1chu
Farmington, Connecticut
Does the Unication G5 use a programming/charging cable that is proprietary or are there other cable options?
hazrat8990
Wyoming
The one that comes with it is a bit thicker and has a ferrite attached, but any micro USB cable will work.
CanesFan95
Was Homeboys-Scanna
FL
Not proprietary. But I did once have an aftermarket USB cable that work fine for other devices not work with the G5 for some reason. Then I switched to the one that came with the G5 and then it worked. Cannot explain why.
Because some cheaper USB cables are charging cables and not data cables.
