TRX-2: Gloucester County NJ P25 will not receive.
mfc11255
Minotola
I can not get the Gloucester County NJ P25 phase ll simulcast to work on my TRX-2. I have Atlantic County NJ working fine.
tvengr
Well Known Member
Baltimore County, MD
Which county are you in? If you attach your Gloucester County configuration file, I will be happy to take a look at it. Click on Attach files and open the file. As RaleighGuy just mentioned, the problem very well could be simulcast distortion.
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
As previously mentioned you're going to have a horrible time with simulcast systems like Gloucester County's scanning with anything other than a Uniden SDS100 or SDS200. Being from just outside Philly I'm familiar with that very system as well as the counties' simulcast systems surrounding it. You can try the multipath mitigation methods outlined in the wiki linked below, they may or may not work. If I were you I'd sell the TRX-2 and pick up an SDS100 or SDS200. Trust me it'll be a night & day difference
That's because most of the sites are single-cell (non-simulcast)
tvengr
Well Known Member
One thing to check: Atlantic County uses 800 MHz frequencies. That will work fine with the Standard trunking tables. The Gloucester County system uses 700 MHz frequencies. Under the Site Options tab in the EZ-Scan software, Trunking Tables must be set to Auto Fill for the Gloucester County system to work.
