GMRS/FRS License confusion - What's true?
sfgiantsradio
I have read that you need a license to use 462.5625-462.7125. I have also heard that you don't need a license. Does anyone have the real answer? I think that we all need the real answer.
I think that you do need a license. What do you think?
SkipSanders
Silent Key
There are FRS frequencies, and GMRS frequencies. 7 of those frequencies are shared by both services.
On the shared frequencies, both may operate, and may talk to each other, as well. However, FRS stations on those frequencies are still limited to half a watt, and fixed antennas. GMRS stations on those 7 channels are limited to 5 watts.
Operation on the GMRS-only frequencies, or on the shared frequencies with more than a half watt, or with a removable antenna or external antenna, requires a GMRS license.
hockeyshrink
I think, think of it in terms of the equipment you are using:
-- Bubble pack FRS/GMRS radio (500mw, fixed antenna) - no license
-- Part 90 radio programmed to GMRS frequencies (variable wattage to 50 max, removable antenna for external connection) - license required
Does that work?
N
N_Jay
Guest
Does that work?
Close.
Bubble pack FRS/GMRS radios on FRS or shared FRS/GMRS channels > No License
Any radio (Including FRS/GMRS pubble pack radios) on GMRS only channels > License
Part 90, Part 87 (Ham), or Part 95 (GMRS) radios on FRS only frequencies > Not legal
Part 87 (Ham) radios on any GMRS frequency > Not legal
hockeyshrink
Close.
Roger roger....leave it to the US Government to take something fairly straightforward, like a GMRS service, and totally turn it into a confusing mishmosh of muck
ty N_Jay
N
N_Jay
Guest
ty N_Jay
Would you prefer they left it clear and simple? No FRS, and all GMRS needs a license?
Thunderknight
Bletchley Park
Close.
Ham is Part 97, not 87.
ArtU
I think it would be someday the reverse; GMRS is like the old Class "A" UHF CB from the 60s.
Class "D" CB was 11 meters. Folks forget "CB" had four classes when it was created.
My forecast is as years pass, all FRS/GMRS will be license free some day shortly. The manufactures are pushing this and do it by making radios that require a GMRS license, sell them to anyone; but most folks never get the licenses. Just like the old days; once it gets all out of hand, they just will drop the license like they did with class "D".
ArtU
N
N_Jay
Guest
It is exactly that, and it needed a license then also.
ArtU
I hope not.
Except those radios don't do repeaters and are (mostly) low power.
Maybe not. Maybe the FCC has learned. (maybe?)
SkipSanders
Silent Key
The most likely thing if they remove the license, is that they'll remove repeaters, too. And remove 45 watts. Welcome to 5 watt simplex. If you're lucky, you might be allowed a removable/external antenna.
ArtU
I hope not.
What has the FCC learned? It learned that it saved money and hassle by not requiring licensing. Manufactures learned non-licensing means more profits and more sales.
Why do you think MURS and FRS was created by the manufactures on frequencies that needed license in the past? Manufactures lobby FCC for less rules for more sales. More sales produce products with more features.
Have you ever been involved with the radio wholesale or retail business?
nhscannerman
Nashua, NH
OK let me put it this way. I say have the FCC make private channels for the FRS and leave the GMRS frequencies alone
ArtU
That would be nice for all of us, which is why it probably won't happen according to my Prognostication :(
I hope I am wrong...
