..............................................I did what you said exactly n it did have 001 selected as the default but I picked it anyways.....the transfer took allot less time..............The end result is that I still cannot hear anything....................................................are there possibly other boxes that might need to be checkered the EZ?
From the EZScan Manual (PDF)(page 37):
"NOTE: The Default Scanlist is always pre-selected for your convenience. If you do not want to import your picked objects into the Default Scanlist, be sure to unselect it before importing. You can change the Default Scanlist in the Settings Menu or with the PSR-800 PC application."
_______________________________________________________________________
My Comment: This has to do with "importing" new "objects" into Scanlists for editing and monitoring. If done with the software these "usually" come from the "Updated Library" in the software. If done in the radio the importing is from the Radio's onboard Library into scanlists for monitoring.
Personally, I make so many changes to Scanlist names, order, objects, etc., that I ignore this "default" setting. An "object's" Scanlist can easily be changed anytime (in the software) from the "Conventional Frequencies" tab, the "Trunked Radio Systems Tab", or the "Scanlists" tab. Just change the number in the right column on any of those tabbed pages. From the radio also, but I have never done that.
From the EZScan Manual(PDF)(page 47):
"IF an object is mapped to an enabled Scan List, AND, that Scanlist is enabled, AND, that Scanlist is a member of an enabled Scan Set, THEN, that object will be scanned when the ▶/II/SEL key is pressed."
Comment: You have not used the term "Scan Set". "Scan Set" settings can be found on the "Advanced Features" tab page. Make sure that (for now) Scan Set #1 is "enabled" (solid black square) and the others are empty squares. I give this warning because I had my radio a couple of months before I realized that "Scan Lists" and "Scan Sets" are not the same things. Heck, the settings boxes are pretty much alike, and if you don't look closely you can wreak havoc with the "Scan Set" settings, lol.
________________________________________________________________________
Paragraph Two from my last response to your thread:
"I followed along on this while I was typing and I bet I found something relevant to your problem that I completely forgot about earlier. Near the end of the above, between Continue and Copy Folders, do you see more than one "Folder" in the selection box? If so, your configuration may be only in one of the "Folders" shown. You can select the proper "Folder" from the radio. Let me know if you need the steps for that."
_________________________________________________________________________
My Comment: This second paragraph is regarding a completely different subject then the first paragraph in said response. Please let me know if you see MORE than ONE "Folder" at that step (between Continue and Copy Folders) in the "Copy Configuration to ScannerMemory/SD Card" process. If so I will post the steps to take using the radio to make a selection (done after copy from computer completes).
