SDS100/SDS200: GPS Cable
K2KOH
Silent Key
Putnam County, NY
Interesting thing happening with my GPS cable. Plug it in, GPS works, apparently powers the radio, but no red led to show charging. No complains since it powers and GPS works, but just though this was weird. LED is one with my other cables when connected to power or my computer. Bought a new cable just in case.
nessnet
What month is it?
Not sure this is it from your post, but.....
If you ever get the low voltage (whatever the error says), it automatically resets the charge while on to off.
You have to manually go re-set it to on, if you ever get that error.
RBMTS
Check your settings. Settings -> Battery Options. There is a setting to turn charging on/off when the radio is on. If it is set to off (not charging), the red light will not be on.
K2KOH
Silent Key
Putnam County, NY
Tomorrow I have to check the voltage out of the USB port in the car I'm using. It only happen with the GPS cable. Thanks!
phask
zanesville
If charge while on is set and the voltage drops too low it resets it to not charge.
K2KOH
Silent Key
Putnam County, NY
Well, I've come to the conclusion that more than likely there was a drop in voltage for whatever reason. Input voltage reads 4.5 volts. Bought a second cable....just in case. Thanks for the replies!
