If they spit their review out already - you'd probably figure out who was a beta tester then their PM boxes would be filled up :>
rckydenver said:Check out the second picture, on back of the box tells what is included.
When you're looking at the TGRP you want in SL02 (PGM mode), up/down arrow to the "Scan Lists" menu item. Then, on that item, left/right arrow through the Scan List numbers. An asterisk (*) will appear if the TGRP is in the displayed Scan List - press SEL to toggle it on/off.dpm3 said:I've mastered the programming of conventional objects with no problem, but the trunk system thing keeps giving me fits. I want the local (StL PD - 800 mHz Motorola) trunked system in Scan List 2 and conventional type local PDs only in Scan List 1. No matter what I specify in the setup process the StL PD system shows up when scanning Scan List 1. I'm missing something here, I'm certain. When I try to scan List 2 it tells me "Nothing enabled" (or something like that. Any help would be appreciated. I'm about 4 hours into the learning curve and have hit a wall on this one.
Asterisk next to SL number in "Scan Lists" menu item means the object is a member of that Scan List. Remember that an object can be a member of any, all, or none of the Scan Lists.dpm3 said:I'll need to reprogram and look. If you'd be so kind as to explain the significance of that while I do so (I no doubt continue to miss it in the manual) and how to rectify, I'd be grateful ...
tbhausen said:My stock ducky is quite tight. Maybe rotating 1/2 turn and re-attaching would firm up looser ones?
Mine has a "minor" fit/finish issue. The clear LCD window is flush with the gray face plate an all but the lower right corner (it sticks up maybe 3/4mm). The window appears to simply be thicker on that corner. Anybody else see that?
LEH said:dpm3,
From the pages of been there done that.
As already pointed out, there is an asterisk (*) next to the scan list number. The system will appear in whichever list(s) has an asterisk.
San Mateo County ( http://www.radioreference.com/modules.php?name=RR&sid=1138 ) works well.Has anyone loaded and gotten to work a UHF Motorla trunked system?
