radionut44 said:
I don't have my radio yet...it comes Monday. But from reading the manual I think you need to set up the widcard TGRP for that system in order to get the OPEN operation. You can then LOCKOUT that wildcard TG to go to CLOSED for that system. You would just ned to know the ID for the wildcard object to quickly access it to change lockout status.
Ron
I get what you are saying, but there is no "open" or "closed" on this radio, but it is similar. Any talkgroup locked out will not be scanned again with the wildcard.
You can review the locked out objects by pressing PGM, GLOB, scroll down to the SRCH L/O item, press select and scroll through the locked out objects one by one and delete them from the lockout list using the CL or Func + CL to remove the whole list of lockouts. Pretty cool, I think.
You can also go directly to the object if you know its number, MAN (or PGM)#object number# E, and scroll down unlock it.
"Applying wildcard lockout to an undesired talkgroup creates a
new TGRP object in the same Scan List as the wildcard TGRP,
then applies permanent lockout to the new TGRP object, so that
will be ignored in the future by the scanner when scanning the
wildcard talkgroup. To unlock or edit talkgroups locked out using
the wildcard lockout feature, press PGM, then navigate to the
object using the 5-way pushbutton pad. Press FUNC, then L/OUT
to remove permanent lockout from the talkgroup. Press FUNC,
then CL to delete the TGRP object from the scanner. Press the
EDIT, then the CURR softkey to edit and save the TGRP object."
