RandomK
fmon said:Don't know Tim,
I just imported the system into both softwares and got the 6 freqs and 72 TG's in scanlist 1. Should work other then the few PD encrypted.
Hmm... I'm starting to wonder if I have a hardware problem!
Tim
Could be, though haven't heard of this problem yet. Try MAN F2 F3 and step to a voice frequency for awhile.RandomK said:Hmm... I'm starting to wonder if I have a hardware problem!
Tim
fmon said:Could be, though haven't heard of this problem yet. Try MAN F2 F3 and step to a voice frequency for awhile.
RandomK said:Stepped Thru and only thing I get is the Diesel Engine on the Control Channel.
Tim
kd2pm said:I know most of PA is going MACOM Opensky but if you are hearing a dedicated control channel, that would not be it.
You can also try opening up hyperterm on the PC and use the CCDUMP feature on the scanner to see what kind of data you are getting. If you can read it, chances are, you should be able to hear the voice channels. (Did you enter all the channels of the system or just the CC's?)
yaesumofo said:While the memory system may be a bit more difficult to get one's head around than a 396's memory system,
yaesumofo said:Imagine how many objects can be programmes into a 1 gig sd card which costs $10.00.
kikito said:Although that would be nice, it's not as easy or cheap as it may appear. Are there any radios right now (amateur, receiver or else) that have it now? I'll like to check them out, just out of curiosity...
swest90 said:Kikito just doesn't get it,...
This would consume 18 of the 21 'scan lists', on the psr500 in order to get the same result and leaves out countless other municipal police and fire departments. Do you get it yet? We are past the point of linear lists.
Kikito just because it hasn't been done before doesn't mean jack s..t. They can design these things anyway they choose. An SD memory interface would not greatly increase the price, the digital camera manufacturers don't seem to have a problem including it on sub $150 cameras.
I can only hope next time GRE gets someone to test these outside the sticks, and perhaps even get some professional users opinion.
And thank you Mr Starr for pointing out to create the systems at once so they are at least in some sort order when you cycle through the objects.
yaesumofo said:That is the point. GRE Passed up an opportunity to become a leader.
The point is that it is a really affordable both to implement as a manufacture and to fill the slot as an end user. GRE choose to not do this for some reason which is beyond me.
I would wager that UNIDEN will have just such a slot in their next generation top of the line radio.
This memory can be used for multiple purposes. One is to expand the channel memory another is to save a LOG and yet another is to record audio and save the audio files memory. Pretty darn useful if you ask me.
yaesumofo said:GRE and uniden are not interested in serving customers needs. They are focused on making money. Too bad Companies like Yuperitu and AOR can't get it together to make a decent quality APCO 25 scanner.
Yaesumofo
kikito said:Yes, I DO "get" it.... :roll: I also get that you don't seem to have found a way to make it work for you or don't want to. Even if it means to consolidate and rethink your whole arrangement strategy. I guess I'll stop wasting my time trying to give suggestions on the matter....
I strongly encourage you to sell your PSR-500 if you have one or not buy it at all if you haven't done so. Problem solved. Wait for the next best thing....
Eng74 said:Did I miss something, how do I have the 500 show the name of the scan lists that it is scanning. It runs the ch. tags but I would like to see the name of the scan lists like the 97 when there are no transmissions.
Number 3 is scanlist on bottom line. BTW the tag is for TSYS. Adding a 4th for conventional with CT.Eng74 said:Did I miss something, how do I have the 500 show the name of the scan lists that it is scanning. It runs the ch. tags but I would like to see the name of the scan lists like the 97 when there are no transmissions.
bonus1331 said:I think the point is, why should we have to consolidate when there is already a product that allows us not to? (396, 330, 15, 996).
