GRE PSR 800 Pre Release Thread
cipher66
ARTCC DB Manager
Highland, IL
DonS, or anyone that might know,
I am very interested in the recording capability of the PSR-800, and would like to use it for unattended monitoring sometimes. If I were to power up the radio, and scan objects that are tagged for recording, could the radio's volume be turned all the way down (silent), and it still record the active transmissions for me to review at a later time? Also, will each .au file be tagged with the freq, date, time???
whsbuss
SE Pa
sdCard
Can the SD card be replaced with a larger capacity? I have an 8gb just sitting around doing nothing. Would love to keep recording on SD card.
DonS
Franktown, CO
The scanner's audio volume setting has no effect on the recordings (until you play them back, that is).
Each file is tagged. The info is in a header at the start of the .AU file and is displayed when playing back on the scanner. The PC software can create more descriptive file names and directory structures based on that info.
DonS
Franktown, CO
Any microSD Card up to 32GB is supported, as long as it uses 512-byte blocks (I've never seen one that doesn't, though the SD spec allows it) and is formatted correctly:
* 2GB or smaller: FAT16, 32kB clusters
* larger than 2GB: FAT32, 32kB clusters
cipher66
ARTCC DB Manager
Highland, IL
Thanks DonS... I'm seriously considering getting one of these now.
Sent using Tapatalk
DaveIN
Founders Curmudgen
West Michigan
That would be great and I would expect it to be compact, but you do know the 500 has a mobile version called the PSR-600 right?
wm8s
Houston, TX
The PC software does support pasting from the Windows Clipboard and importing from text files.
Is it somewhere to download where we can get a headstart on programming? Thanks!
...R
jafolives
Denver CO
Yes, was considering the 600 but was just wondering ( more like drooling ) over the 800
TES
America's High Plains
Looks like this won't be the "Pre Release Thread" much longer. From the February 4th, 2011 GRE Newsletter in my (and many others?) inbox this morning:
Dear Valued Customer,
Feb. 4th 2011...With Successful completion debut launch of PSR-800 at 2011 CES in Las Vegas, Today GRE starts to ship initial 1st production of PSR-800 to its dealers and retailers.
Wonder how GRE defines "starts to ship"?
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Hi TES,
Mine had a DTG 02/05/2011-0056 meaning anytime after midnight this morning.
RadioDaze
Orange County, California, USA
Awesome. Groovy. Kewl. Fa-a-a-a-a-r out!!!!
wyomingmedic
I am reading this thread with some certain interest, but until now, I have not felt the need to comment. It has been alluded to a few pages ago, but I will write up my little piece.
First and foremost, I am a certifiable radio nut. 10's of thousands of dollars wrapped up in ham radios, antennas, towers, computers,ETC. As of last year, I have really been embracing the scanning side. Primarily digital scanning. I have outfitted my vehicles and home with most of the wares from GRE and Uniden (NOT the HP-1) and Motorola.
One thing that has continually bothered me about GRE and Uniden is their complete lack of handling a multi site, simulcast system. Here in Wyoming, we have our statewide linked system. From town, I am LOS of several very high level sites, all simulcast, and all VERY close in frequency, and all on top of the VHF paging band. This is a VHF digital scanning nightmare.
The general convention is to attenuate your scanner and try to prevent the overload. I actually use an 800 MHz antenna on VHF, PLUS the attenuator, while I am in town. If not, it is futile to listen to the system. But the other problem comes when I leave town. I have to completely shut off the attenuator AND put on a proper VHF antenna.
I certainly wish BOTH big digital scanner companies would send some test units to Wyoming or a place like Wyoming, where you are fighting massive intermod/multipath issues on a very large simulcast system while also fighting extreme distances between towns.
I also struggle with the physical build quality of these products. Poorly made plastic cases. Volume and squelch knobs which do not tolerate extreme cold or hot temps. Displays which do not handle the temp extremes as well. I understand there are limitations to the LCD properties as well as the knobs. Uniden holds a SLIGHT edge over GRE when it comes to cold weather functionality.
I guess the point of this rambling post (if there is a point) is, who actually tests these things and in what environments (RF and physical)?
WM
scandan780
west central florida
manual?
Does anyone know where I can download the manual? I've tried the fcc site but the manual does not load for me. I've also looked at the GRE site and can't find it. I will be purchasing this scanner and wanted to get a jump on it and start reading the manual. If someone has it could you e-mail it to me.
Thanks,
Dan
dollar
Toronto ON
Physical Size
What are the physical dimensions of the PSR-800?
DaveIN
Founders Curmudgen
West Michigan
DIMENSIONS
Approximately 5 5/16 x 2 1/8” x 1 1/16” (135 x 67 x 28 mm) (HWD)
WEIGHT
Approximately 7.4 oz. (210g) without accessories and batteries
And here are the PSR-700 specs. to compare to:
Dimensions (HWD) 4-15/16 x 2-5/16 x 1 inch (127 x 60 x 27 mm)
Weight 6.7 oz. (190g) Without antenna and batteries
This means the existing case from Universal Radio and Scanner Master will not work, unfortunately.
