If your using a TPRD-1546C, I'd add a single 10" band pass cavity centered on your repeater input.
Keep in mind you are adding more insertion loss if you add anything to your receive chain.
If you are using a Q2330E, and you are getting -90 to -100dB of rejection with -1dB of loss, I'd do a desense test once it's all installed and see what it shows.
185w seems really excessive for transmit power especially if you are using a SD2352-HF2PASNM, even at 300+ feet AGL. Is it fed with 7/8 or 1-5/8" hardline? If it is, you have quite the alligator of a repeater. Portables at 5 or 6w and mobiles at 50w.
Your repeater is going to have an ERP over 500w, fed with 7/8" hardline. If its 1/2", it's almost 400w.
Honestly, it's nice to see someone is using quality components, but man, power out, isn't everything.
