And DMR APRS would be a convenient way for tbe caller to share their location.
Between that, and the backbone required to route it to the appropriate agency, plus have a a way to get back out to the initial caller, it doesn't seem feasible. With the millions of dollars already spent on GPS 911 routing that isn't close to always correct, I don't see it happening.And that makes even more sense.
But I can see some brining up a "liability issue", realistic or not. If done correctly and making sure end users understood their was zero guarantee of anyone answering or being useful, then maybe that would fly.
On the other hand, I've attempted to rely on amateur radio operators to answer emergency calls before, and was seriously disappointed. I'd still not rely on it as my only means of getting help in an emergency.
I thought you were going another direction, but I agree with you 100%. Unfortunately, I've found some have a hard enough time looking up a call sign with QRZ or the FCC database, asking one of them to look up the local PD phone number to relay information to is significantly improbable.I don't think you and I are talking about the same thing...
I believe the idea proposed was to set up a Talkgroup #911 that would be monitored by hams only. No intent or plan to route radio calls to an actual PSAP. I agree, doing that would be a horrible idea.
But having a 99.9% chance of reaching a live/intelligent ham operator that would at least place a phone call for you would be useful if you were outside cell phone range.
I won't be getting rid of my Garmin InReach anytime soon, though.
It might not hurt to have someone at an actual 911 center monitor that talkgroup to cut out the middleman. Sort of like how some agencies used to monitor CB channel 9...I believe the idea proposed was to set up a Talkgroup #911 that would be monitored by hams only. No intent or plan to route radio calls to an actual PSAP. I agree, doing that would be a horrible idea.
They answer all cell phone 911 calls then route based on location if necessary.
Not always. Most cell phone calls route to the correct PSAP for the location.
however, NG-911 will fix a lot of the issues with the current E-911 system, and make it much easier to route calls to the correct PSAP.
I think it’s a “YMMV” situation. Every time I’ve called 911 from my iPhone, it’s gone to CHP. They took my call then transferred me to the appropriate agency.
It's not something that is left up to chance.
The latest statistics show that somewhere above 80% of 911 calls are from cell phones. If 80% of the 911 calls had to go through CHP, there'd be a big mess and a lot of delays.
Cell carriers have become pretty good at determining cell phone locations. PSAP's can provide an area of responsibility, and calls will get routed correctly. When locations cannot be accurately determined, or it's outside of a specific area that belongs to a certain PSAP, they will route to CHP.
Ham radio will not have access to those systems, and no PSAP is going to install ham radio gear in a center and assign staff the responsibility of monitoring. Most PSAP's are understaffed as it is. Ham radio operators will have to do this one on their own if they want it to work.
It would be a great way to actually prove they can do "EMCOMM".
Now I imagine the same could be said for any spot in the US as well. It could be better if some group actually took the time and got cooperation with public safety agencies to use GIS data to provide a easy to lookup system for PSAP numbers for each and every spot in the US but I doubt that will happen. I talk to dispatchers all the time who can’t get that info and they have access to way more resources than any of us.
I dont see this idea ever becoming possible.
At the end the day, the sat phone is the only realistic option if there is no cell coverage.
