Handling Patched TGs with Trunk Recorder and Calls
IcomIcR20
I just set up a calls node using Trunk Recorder and the Broadcastify Raspberry Pi Image for the MMCCD P25 Harris system (Montgomery Metro Communications Cooperative District Trunking System, Various, Alabama) and things seem to be working well. However, there are three TGs that are patched together -- Montgomery PD Dispatch (TG 1335), AHP Patrol 1 (TG 1873), and Montgomery County Sheriff TAC 1 (TG 291) -- and these appear on patched TG 20106. In SDR Trunk, the TG appears as "P:20106[1873,291,1335]"
What is occurring now is that only TG 20106 is appearing on the calls platform. Ideally, I would like the traffic to appear as TG 1335 so that listeners can actually monitor the MPD Dispatch traffic which is generally the most active TG on this site. Patched TGs on Harris systems are generally not listed in the database as they can change over time.
Is there anything I can do to achieve this desired behavior with Trunk Recorder? Otherwise, a substantial amount of traffic will be unlistenable on the Calls platform.
DSheirer
Fulton, NY
There's a switch in user preferences to stream audio as the patch group or as each separate group in the patch
IcomIcR20
Thank you, but I am talking about Trunk Recorder, not SDR Trunk. I provided an example of how the patched TG appears in SDR Trunk, but I am doing the actual streaming to Calls with Trunk Recorder.
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
We got this issue resolved for the OP.
For future reference, we can mark talkgroups on the calls back-end as "priority" talkgroups to be used when a patched situation occurs. Both Trunk-recorder and SDRTrunk sends us the list of talkgroups that are part of a patch. We can pull out of that, in a priority order, which talkgroup should be used to record the call.
Example:
A call comes in as a patch with groups [12,24,33,550,1290]
we have defined on the backend the following "priority" talkgroups in priority order: [550,24]
then this call would be recorded as coming in on talkgroup 550
These are setup system wide for a trunked system. If you need this done for a system, send us a support request to support@broadcastify.com
