Harris unity xg-100 invalid channel in scan list question
UTLForlife
Okay so I've been happily programming my xg-100p the last few months and putting a nice CA state load in a few mission plans.. I've had this alert come up a few times (invalid channel in scan list) and I've been able to work through it more than once.. but it feels like I'm not changing anything and it keeps fixing itself. Of course that's not happening, I am changing something to fix it.. I just don't know what it is. What am I doing! Hahahaha any thoughts would be appreciated.
TLDR:
Invalid channel in scan list, what causes it, and how is it fixed?
UTLForlife
ima take a shot in the dark, is the one of your channels in your custom scan list but not checked off as a scan channel in your freq sets?
So.. I too thought this was the issue but I checked my programming and that System/freq set does not have a custom scan list to begin with.
KE0FKH
Not sure if this is the problem or not but I’ve seen a similar situation happen recently. Is your radio wideband enabled? If not, double check to make sure all your conventional channel sets are set to narrowband. If a channel is set to wideband and is set to scan on a narrowband only radio it will not like it and set off that alert.
UTLForlife
Oh interesting, the radio is wideband enabled. I'll double check the mission plan.
IFRIED91
Arrive alive
NYC area
Make sure you don’t have a setting enabled that requires a feature your radio doesn’t have
ADSNELLC
TLDR:
Because you have a error in your channel settings usually using the RPM. Usually it's a wide/narrow band settings. Also on a XG 100 if you have a wideband feature...and you insert a 70 cm frequency it will default to narrow and invalid channel if you make it a wide channel.
