Harris XG-25P Can't put into program mode INV SYS
hsmcco
Unfortunately I got my math wrong and programmed my xg-25p with too many systems group resulting in a inv sys error. Not a huge deal, however, I cant access the menu to put it into program mode and attempting to hold down the side buttons while powering on is not putting it into programing mode either. Is there any other way that I can put the radio into programming mode?
Forts
Ontario, Canada
I doesn't kick into programming mode as soon as you try to read/write it? It should do so automatically. Do you recall what firmware version it's on?
hsmcco
Last I remember i'm on R06. Im unable to check specifics as I cant open the menu with the inv sys error. I also just noticed after a thorough inspection of my programming cable that the E10 (CTS) pin is missing. Might this be causing it to not jump straight to programming mode?
hsmcco
It shouldn't. I don't use CTS on the cables that I build and they go into programming mode just fine on their own.
Interesting. Is there any other key combo to access the options menu? I can only scroll through talkgroups and nothing else.
merlin
DN32su
The radio should go into program mode when you read or write to the radio.
Bad connection, bad cable are usual reasons.
One of my cables, you need firm pressure on the IDC to make good contact.
