Harris XG100P/BKR9000
tech2461
Bradenton, Fl
Has anyone had the chance to see the new BKR 9000 hand held from Bendix King?... I wouid swear it's a XG100P in a BK case...Is it?
tech2461
Bradenton, Fl
The resemblance is pretty uncanny. Here I started to think that BK cut some kind of a deal to rebrand their Xg100p as their own. Like Tait used to do awhile back.
TDR-94
The XG-100P is a reconfigured PRC-152 and was EOL'd in 2016. It's got nothing to due with the BKR9000.
ResQguy
Meh
If you hold a BKR9000 in your hand and then compare it to an XG100P you'll quickly realize they are light years (and POUNDS) apart.
tech2461
Bradenton, Fl
I've only seen pics and some video about it...To me it looked like it had a lot of the same cosmetic features, that's all.
Giddyuptd
Here and there
To me, BKR a heavy APX pre production housing with square corners and edges with the BKR. Almost like a have blue prototype prior to a stealth lol.
flux4201
The BKR 9000 even has an A/B/C/D switch like the XL200... Of course they could have chosen to go that way..
Mesa AZ
BKR9000 Current pricing sheet MSRP
BKR9000-I BKR 9000 Base Radio Unit Model I Top Display Only, No Keypad $ 2,700.00
BKR9000-II BKR 9000 Base Radio Unit Model II Top Display & Front Display, Nav Keypad $ 2,900.00
BKR9000-III BKR 9000 Base Radio Unit Model III Top Display & Front Display, Full Keypad $ 3,100.00
flux4201
Is that pricing for a fully loaded BKR? or just radio only no features?
Mesa AZ
Radio only and 1 band additional bands are $300.00
VHF 136-174MHZ 6 WATTS, UHF 380-512MHZ 5 WATTS, 700/800 763-870MHZ 3 WATTS, 900 896-940MHZ 3 WATTS
All band antenna $55.00
Battery 5000 mah lith $225.00
Clamshell $55.00
Charger $150.00
PC Programming cable $125.00
Software RES w/ASK $150.00
Cloning Cable $275.00
OTAP TRUNKING $200.00
OTAR TRUNK/CONV $485.00
P25 TDMA TRUNK n/c
DES AES FIPS 140-2 lEVAL 2 ENCRYPTION w/ Tamper proof $465.00
MULTI VOTE SCAN PLUS $90.00
Mesa AZ
I am pretty excited about receiving our dealer demo radios in Jan. The radio may not be every one, but it will be better than Harris or Motorola and lower price. I cannot list what we would sell it for but people are welcome to contact us. I do know we will be offering a package deal to compliment any buyer.
Giddyuptd
Here and there
For the sake of others when those getting them demo them or buy please make sure turn off code is enabled for analog or demand they have that feature available in the software.
TDR-94
I would be surprised if there is anything in common with the PRC-152 and XG-100P. I think they are from two different design groups and made on two different assembly lines.
kb4cvn stated the following in another thread.
Basically the Unity XG-100p is a Harris AN/PRC-152 Falcon-III radio with the following changes:
  • Battery moved from bottom to back (allowing the use of the P7100 style batteries)
  • Display changed from a IR version for NVG use, to a visible light model.
  • NSA Approved Type-1 Cryptographic module replaced with a NSA Approved Type-3 module, supporting DES and AES encryption formats.
  • Main circuit board altered, removing the 30-88 MHz band, and adding in the 700/800 MHz band.
Harris (Rochester) essentially took an off-the-shelf Green Radio, tweaked it a bit, and repackaged it for public safety use. Radios after that were designed by Lynchburg, who have better technical expertise in public safety radios
Colton25
Will the programming cable and software be the same as what the KNG2 uses?
