HAVEQUICK active as of 02/13/2020, 1130h ongoing.
spacellamaman
link and page on first post
RFI-EMI-GUY
I noticed a few freqs missing from the table, or did I miss something?
I think if you start at 20 and work down to 5 you have the 16. The other 4 i dont know, maybe fixed frequency nets on the radio selector?
RFI-EMI-GUY
There is a typo in the last column for channel 20. These are training freqs, and it seems you dont need a full set to synch a radio, it appears the radio might be able to learn its net with only a few parameters. So in tactical use, this document will not be of use. I think the SDR gurus should be able to come up with a better solution.
RFI-EMI-GUY
I guess what I meant was can the radio be set with the appropiate uplink frequency offset for a satellite, CONUS or other.
RFI-EMI-GUY
Which radio? Mine can do satcom, HQ and other stuff. Most military radios that can do HQ can also do UHF satcom.
Just trying to figure out if fleetsatcom monitoring for HQ might be fruitful. I may need to set up my huge Andrew Bifilar helical antenna again.
