Per Whistler it is the same radio,so if you are asking if the head will work then it should work fine!The 1095 is the same radio exactly..........Only difference is the head.Yes.Report back with your findings.Just make sure everything is powered off when swapping anything.Ok?
The head tells the base what it should do.
