Head exchange
kf6mxk
Tehachapi,CA
Is it possible to put the 1098 head on a 1095 scanner?? I have the 1098 in the truck and like the features to be used in the house on my 1095.
Per Whistler it is the same radio,so if you are asking if the head will work then it should work fine!The 1095 is the same radio exactly..........Only difference is the head.Yes.Report back with your findings.Just make sure everything is powered off when swapping anything.Ok?
The head tells the base what it should do.
kf6mxk
Tehachapi,CA
There is no difference in the radios. The 1098 head operates great on the 1095 base. All functions are the same on either base.
