Heard Faint Chatter on 311.000 in North Jersey last night
ecps92
Taxachusetts
AirScan
The chatter was too faint to hear what was being said though.
These EAMs you might hear on UHF are usually being sent from E-6 Mercury aircraft. Did you hear this around 11:35-11:40 by any chance ? There was an E-6 passing by to the west around that time on the 4th.
dlwtrunked
That's one of the EAM frequencies! The other one is 323.800 MHz
And as I am sure you know but others may not, the transmission on both frequencies is usually simultaneous. Not these frequencies are also use at some bases. (323.8 replaced 321.0 for these some years ago.)
eorange
♦RF Enabled Member♦
Cleveland, OH
I hear non-EAM traffic on 311.000 fairly frequently during any given month. It's typically pre aerial refueling coordination.
AirScan
Nevermind, I see you said "last night". There was an E-6 working off the coast for almost 8 hours that night between around 7pm to 2am, maybe that is what you heard ?
dlwtrunked
The message transmitted by them often occurs right after departure.
AirScan
I've only heard them on HF. Are you talking about when they log onto the net right after departure ? I've heard that on HF often.
dlwtrunked
No, talking about EAM...I suspect it is an EAM that announces they (as a command structure change) are airborne. They remote base at times out of Patuxent R. for the Atlantic.
WB5UOM
For me, usually 311.0 is active the same time hf is on EAM's....I usually keep 311.0 on as it is also Barksdale cmd post freq for Mudbug ops. (B52's)
dlwtrunked
They also happen on FSK RTTY (along with MSK) from TACAMO on VLF (the primary TACAMO mission).
AirScan
From the few times I've checked on HF after seeing an E-6 depart is that you will hear an exchange between the aircraft and the ground station confirming entry into the net before any EAMs are sent. Maybe they don't do this all the time ?
In this example recorded on 11175 kHz the E-6 callsign BOAR OAR is calling the ground station FLYBALL.
Audio E-6 entering the net on 11175
I'm guessing these "net entry" exchanges would also be simulcast on UHF but I'm not sure.
dlwtrunked
Entering the HF net should be considered a separate thing. Generally, the HF is not simulcast on UHF; but I have heard operators call up mistakingly on 311 referirng it 11175 and find the station they called does not answer when the do that..
