help blank screen on model 197
RickTheRider
Rochester, New York
I tried to program a new frequency and pushed the wrong button. I dont remember what I typed.The screen went blank. It still has a light when it is turned on and the audio still works but data ( numbers or letters) does not come up on the screen. I dont have a computer to program the scanner. How can I fix this? Thank you.
flythunderbird
Grid square EM99fh
If you don't mind reprogramming everything, you can do a factory reset -
1. Turn it off
2. Turn it back on
3. When the welcome screen appears, press zero, then one, then enter. This will clear everything out and reset the scanner to factory settings. Then re-enter everything.
It's a brute-force method, but it works ...
