Help finding frequencies.
Wildcard03
Hello, I am looking to find a frequency but I cannot seem to locate it. I am looking for the police dispatch frequency for Oak Grove Louisiana area code 71263 any help would be appreciated thanks.
gh6406
Dalton,Ga
Looks like they are on LWIN trunked system.
West Carroll Parish (62) - Public Safety
DEC HEX Mode Alpha TagDescriptionTag
55500d8ccD62-WCSO-DISPSheriff - DispatchLaw Dispatch
55512d8d8D62-EMS DISPEMS - DispatchEMS Dispatch
55519d8dfD62-WC VFD DISPParish VFD DispatchFire Dispatch
55517d8ddD62-WC-PJ OPSPolice Jury - OperationsPublic Works
55515d8dbD62-WC-OAK GR PD1Oak Grove Police 1Law Dispatch
55520d8e0D62-WC-GOODWL FDGoodwill VFD - TacticalFire-Tac
55521d8e1D62-WC-KILB FDKilbourne VFD - TacticalFire-Tac
55522d8e2D62-WC-OAK GR FDOak Grove Fire - TacticalFire-Tac
55523d8e3D62-WC-FOREST FDForest VFD - TacticalFire-Tac
55524d8e4D62-WC-FISKEU FDFiske Union VFD - TacticalFire-Tac
55525d8e5D62-WC-EPPS FDWard 1 (Epps) VFD - TacticalFire-Tac
55526d8e6D62-WC-PIONEER FDWard 2 (Pioneer) VFD - TacticalFire-Tac
55527d8e7D62-WC-CONCORD FDConcord VFD - TacticalFire-Tac
Wildcard03
Thank you, I also have one more question if it’s not a bother how would I go about programming the frequencies into my scanner, for example how would I program, DEC 55500 HEX d8cc
hiegtx
Dallas, TX
I have a Whistler 1040 I have other P25 frequencies programmed and it seems to work fine
Those are talkgroups for the LWIN trunked system, not frequencies. Do you have LWIN programmed? If so, do you have the Oak Grove site programmed for LWIN?
Are you using software, or entering via the keypad?
slayer816
NE Louisiana
I live within range of the Oak Grove P25 site for LWIN. Oak Grove units primarily use West Carroll SO Dispatch for operations (as with other small town PD's in the parish.
I'm no help with non-Uniden radios. However; if @hiegtx can get you situated with the Whistler, I can be of some assistance for local matters.
Wildcard03
I have the LWIN programmed but not the oak grove site and I’m entering via keypad
tvengr
Well Known Member
Baltimore County, MD
LWIN is a trunked system. A trunked system must have at least one site to function. In your case you need the Oak Grove Site in West Carroll Parish:
3 (3)034 (22)Oak GroveWest Carroll769.20625c769.45625c770.08125770.65625770.85625771.20625
The system type should be P25 Auto. The control channel frequencies go into the frequency list for the system. Since you will only be using a single site for now, Multi-Site can be set to Off. You can try receiving the system with SuperTrack on and off to determine which one works better. You only need to enter the 2 frequencies with the lower case "c". Those frequencies are control channel capable. You most remove the "c" when entering the frequencies. It is far faster and easier if you use programming software. For the WS1040, you can use ARC500 or PSREdit500. Both have a free trial period to decide which one you like better. I use Butel ARC500 Basic to program my Radio Shack PRO-106, the older brother of your scanner.
AK9R
Super Moderator
Central Indiana
Since the OP has the frequency/talkgroup information he needs and is now asking about how to program his scanner, refer to his thread in the Whistler forum.
