Help needed Radioshack Pro-2052
ManofSteele1690
Port Orange FL
My Pro-2052 has been working great until one day i hit something and now it will not search within the trunked freqs. I'm located in Florida and cleared the memory of the scanner and entered the EDACS system i have trunk set up for bank one as "ED", it will scan but when i hit search it starts searching all freqs the scanner can use and drops off from trunk, never had this issue until lately, I also have a RadioShack pro-94 with the same bank of freqs set and it searches the trunked freqs just fine and works. any help is good help. below is how i have it set up with what freqs in what order.
002 (2)County East (System - 2/B)01 856.2625a 02 856.9875a 03 857.7625c 04 858.4875 05 859.7125 06 860.4875 07 855.4625
08 856.4875a 09 857.4875 10 858.7375 11 859.2625 12 859.7625 13 860.7375 14 854.3625a
15 856.9375 16 858.2625
wtp
Port Charlotte FL
from the videos i have seen you hit the scan button to scan the systems you have entered.
maybe you locked out the control channel ?
so, maybe go through the channels and see if any are locked out.
ManofSteele1690
Port Orange FL
per the manual to scan edacs system you hit trunk then search its what i have always done but all the sudden something happened or i hit something and its no longer working in that manner just looking for some insite form anyone that might know what im doing wrong.
ManofSteele1690
Port Orange FL
reprogrammed bank 3 with the same freq as my pro-92 seems to be working besides a few static pickups on the pro 2052 vs the pro-92 but could just be the antenna
  • Like
Reactions: wtp
