Help NXDN
peluson
Hello, does anyone know if there is any way that the AOR-DV1 with a wav recorded on its sd is capable of deciphering the NXDN code? or in some other way.
peluson
hello again, what I try is to pass through the AOR-DV1 the external audio either recorded in the SD or that the signal enters so that it detects the key of the 15-bit NXDN scrambler.
G7HID
Box 500 Slough UK
Cannot think of an easy way of doing it...
Might be easier to take the DV1 or a DV10 to the source of the scrambled signal, as long as the scrambled signal is NXDN 4800 and not NXDN 9600. Also be sure it is NXDN basic privacy scrambled and not add on encryption..
Mike
peluson
Hi, ok unfortunately the NXDN48 encoded signal is not in the vicinity and I receive it through a remote SDR.
peluson
I receive an NXDN48 remotely encrypted by an SDR, as I have explained previously and I would like to be able to listen to it through the AOR, thanks
harryshute
Edmonton, Alberta, CANADA
Try this RR post in 2021.
peluson
Thanks anyway, but that's not what I'm looking for, the way to decode with the AOR is already documented on the web, what I need is to know if it can be made to decode with a signal that is not live, but recorded on your sd or through an external sdr.
LimaZulu
A little bit late to the party. Don't know if the author already found the answer but since I already know it - let me share it. Unfortunately there is no way the obtain the code that way. It can only be done while receiving the signal over the air.
