Hey, i have a TK-8160 and i recently had it programmed. It has FleetSync PTT ID set up to Transmit the Data Packet Before and After the transmission. (i only want it to transmit the data packet before the transmission)
Also, Channel 1 or my DISPATCH Frequency was programmed incorrectly and needs to be changed. It was programmed as a Repeater channel with a Input and Output frequency. (i need it to be simplex) Im sending this radio to a radio shop in Aurora, Colorado. They program mostly Motorola radios and offered to program this radio. They have no experience in programming FleetSync (and i was told will not attempt to program Fleetsync with out instructions).
When they go to re-program the radio all im having them do is switch my DISPATCH frequency to simplex. But it still needs to have the FleetSync PTT ID on it. Can they make the frequency change without changing any of the FleetSync settings? If not, Can someone give me step-by-step instructions on how to program FleetSync PTT ID with a Fleet ID of 106 and a ID of 1639, so i can give them instruction on how to program correctly?
If you can help, email me at zlegleiter@cox.net or just add a comment here on the thread.
Thanks in advance!
Zach
Thanks in advance!
Zach
