Help USB-1 cable
techynyc
If anyone in the RI area has a USB-1 cable for programming a Uniden 396XT scanner could you message me.
I am trying to help an old Vietnam Vet program a 396XT scanner but he doesn't have this cable and its back-ordered for months.
I just need it for connecting to ProScan and than uploading frequencies. Promise you'll get it back.
If you come down to hand out with us we'll buy you breakfast and give your a tour of all his radios and scanners.
Techynyc
techynyc
Only cable they have is the power/charging cable. They don't have any other cable.
In order to program this radio I need Uniden's proprietary USB-1 cable.
laidback
RailFanning is a way of Life
Northeast Indiana
Who are "THEY" ? You need either cable listed above.
mancow
N.E. Kansas
No idea why people are being all tistic about this. I have the cable. Send me your address (via private message) and I'll ship it to you to borrow.
fxdscon
¯\_(ツ)_/¯
Re-read the OP’s first post. He’s programming the radio for somebody else and they stated that the only cable they had was the power cable.
Neither of the two cables listed above your post will work without the original Uniden serial programming cable that came with that scanner… which he stated he does not have.
Thanks to mancow for stepping up.
W1KNE
No Filter Zone
New England
Mancow beat me to it, but I also have one (somewhere) that you can even just have if you want it. (I have to find it in my cable drawer in my office.)
KK4JUG
GA
My father used to call this "making a mountain out of a mole hill."
fxdscon
¯\_(ツ)_/¯
laidback
Northeast Indiana
Depends on if your computer has a 'serial' port if NOT you need 'usb to micro usb' connecto. Look at page 56 of manual.
Laptops newer do not have serial ports, some of newer desktops do not have a 'built-in' serial port, you can get a PCIe expansion card for your newer desk top, or just get a 'usb to micro usb' cable.
fxdscon
¯\_(ツ)_/¯
Once again..... A micro USB connector on the scanner end of the cable cable will NOT work. The BCD396XT does not have a USB micro socket on it.
The cable in your post #14 will work. It's not using a micro connector, and it has the USB to serial convertor built in to the cable.
Ronaldski
MI DB Admin
Bay City MI
Cable sold out as mentioned in the first message. Actually that's a common thing over the years.
Mancow certainly going out of his way and stepped up!
Granted borrowing would work, but there's always updates, changes to be made, just a lot better situation if the cable for it is readily available.
This would work too, cheaper cost and assuming windows is okay with it. Looking at a few reviews seems to be. It doesn't list the 396xt, but that model 396T and the 396XT has the same connector. I've owned both models.
Amazon.com: USB Serial Programming Cable for Uniden Bearcat BC250D BC296D UBC3300XLT BC246T BR330T BCD396T BC346XT : Electronics
Other way would be to acquire the cable that came with the XT and get the serial usb-serial cable I mentioned above in message 3, total cost some 19-20 bucks. I know that works. :)
fxdscon
¯\_(ツ)_/¯
What is the port on the side of unit for programming ? "mini" usb
No, it's not a mini USB, it's not a micro USB. It's a not too common Hirose MQ172X-4SA 4 position serial data connector.
The BCD396XT can not be connected directly to a computer's USB port... It must have a serial to USB convertor in between.
Ronaldski
MI DB Admin
Bay City MI
So what have you done? Borrowed, bought cable(s) or non of those a yet?
