Help with BC_VUP_v2.0.0.3
k1mri
I downloaded BC_VUP_v2.0.0.3.zip, installed it and it's looking for the .scn file. Where is that located?
Thanks.
Deeke
UNZIP the BC_VUP_v2.0.0.3.zip file and it will appear in the folder where you save it.
k1mri
Nope not there. All that's there is BC_VUP.ini configuation file. Nothing else.
What does this firmwae do anyway?
n2mdk
Ames, IA
The firmware is basically the operating system the scanner uses. Check what version is already on the scanner the latest is 1.03.04. You can check using Menu>Settings>See Scanner Info>Firmware Version.
You need to download the firmware update it's not contained in the BC_VUP download, it's a seperate download.
k1mri
The firmware is basically the operating system the scanner uses. Check what version is already on the scanner the latest is 1.03.06. You can check using Menu>Settings>See Scanner Info>Firmware Version.
Mine is version 1.03.04
Where/how do I get the firmware?
n2mdk
Ames, IA
You have the latest I was looking at the wrong firmware uodate.
The firmware is on the Uniden website just like BC_VUP is, it's also in the files section of the Yahoo BCT15 group.
n2mdk
Ames, IA
