jerkwithacamera
- Joined
- Feb 25, 2022
- Messages
- 4
I have just picked up a 5700-k and I am having issues with connecting to the radio to modify the programing it came with from my dealer. When connecting it to KPG-D1N using the KPG-46z Cable no matter what computer I try or what Prolific serial driver I use I am getting the error "check all connections and COM port Settings". Checking the Prolific chip version it is a PL-2303 TA which should work with out issue on windows 10. I only have the one radio so I can't test the cable with a different one but I suspect that the cable my be bunk and I have a new cable on order and hopefully it has the FTDI chipset as promised.
That all said what is curious is I cam getting the same error with the Bluetooth connection. When changing over to the Bluetooth SPP in settings it finds my radio fine and It does connect to the radio via Bluetooth for a quick moment and then it will disconnect resulting in a "check all connections and COM port Settings" error. Like I said I have tried many windows 10/11 computers and many serial-usb drivers for the cable. I found an older thread here about the Bluetooth data check box and the other Bluetooth options in optional features, but all to no aval. I would take it back to the dealer but they are a very long way away from where I am at :| what else might I be missing to get this connected/programed with Bluetooth?
Edit: I forgot to mention that my radio firmware is up-to-date 4.5.1 - 421C and the KPG-D1N is also up to date at version 4.51
Thanks in advance!
Thanks in advance!
