help with Trunk system
FCVPI99
Rockford,IL
have i programed this right? im not used to VHF trunking ....
on my Pro 197
thank you
ScanWI
MN & WI DB Admin
Wisconsin
It looks good, however those agencies don't use WISCOM for daily operations. You will want to add the State Patrol talkgroups and other interops. You won't hear much on the stuff you have programmed.
FCVPI99
Rockford,IL
i should be able to hear everything just cuz i didnt program a talk group doesnt mean i dont get it in at least thats how it was on my Pro 96 back in the day
FCVPI99
Rockford,IL
well being Beloit PD isnt on the Beloit channels the only other place is the state system ... i would guess
VASCAR2
So Illinois
I haven’t monitored Rock County, Beloit or Janesville since moving out of the area a couple years ago. At that time each agency was using conventional P25 frequencies with non trunked base repeater systems. Most traffic was in the clear but the Tactical channels were encrypted. Here is a link to the database.
ScanWI
MN & WI DB Admin
Wisconsin
Nope, you aren't using a Pro-96. If you want to hear everything on the site you need to program a wildcard talkgroup.
ScanWI
MN & WI DB Admin
Wisconsin
Beloit is on the PD channels, they do use encryption on their channels and they are also simulcast. It could be that you scanner is having issues with the simulcast or the encryption.
FCVPI99
Rockford,IL
im starting to HATE this OOM scanners .. lol ok so i want a wild card ... uggg man i miss the channel memory scanners .. so much easier to program
FCVPI99
Rockford,IL
i get janesville and and Rock county nac stuff i assume i can get the truck system in but again no way to really check on the 197 that i know of yet still learning the radio .. i have heard nothing on the 400mhz freqs so i assume they were on the trunk system ... i have to get me a 2096 lol
VASCAR2
So Illinois
I’ve programmed all the Pro Series and Whistler scanners from the key pad. The Wild Card is a setting to receive any talk group that is not programmed into the scanner. On a Pro 197 on a trunked system you only receive unlocked Talk Groups that programmed into the scanner that are not encrypted. Turning on the wild card lets you hear any unencrypted talk group that transmits on the tower/site your receiving on a trunked system.
The Mark’s easy to read scanner manual makes it easier to figure out how to do task in programming from the key pad without using software.
If you still have issues understanding your Pro-197 you can send me a message on this forum. We can exchange emails or I can give you my phone number. I’m retired and have the time to help.
