Help with Vertex VX-829 P25
kb9hgi
IL
I got the cable and software and programmed the 829 P25 and the analog sounds fine but the ones I have that are P25 is choppy and cuts out. Do I have this think program right? attached is a screen shot.
radiotweester
Oregon
Screen shot is tiny. Is it a bunch of P25 channels or just 1? Could the RX strength is low? Listening on a second analog unit do you hear signal fade/packets being dropped or a continuous burst? Try RX NAC of F7E and SQL of S and you can lower the squelch that way. See if it does the same.
I'm NOT a Talon user so I'm going off CE-76.
Without the right equipment it's screwdriver tech stuff messing with Common -> Modem setting and Radio -> CH fine tuning and RSSI levels. If it's a simulcast system, I don't know if Vertex play well on those like Motorolas do (C4FM or CQPSK).
kb9hgi
IL
No its 3 P25 conventionals and the others are analog. It picks up the P25 freqs but they cut out and no they are not simulcast. The towers are local and strong. I can hear them fine on my 436HP. I bought this radio off ebay from used radios they refurbish them.
radiotweester
Oregon
OK. Hopefully one of the Talon owners will speak up. It could indeed be the radio. You might try making sure the modem is totally seated by giving a soft push. I know it has the screwed down cover that SHOULD hold it in place I've seen other acc boards not quite sit right and cause weird things....
I don't have either a Talon or CE-76 P820 or P920, but try the squelch setting in the pic.
I think with your scanner receiving better than the radio, I'd be considering an exchange.
Apologies for not being more of a help, but all my P25 equipment is Motorola. 73s
