Hemet, CA - Police: San Jacinto woman arrested after making threats on police radio
mikepdx
Corbett, OR USA
The FCC created this problem; when they put Part 97 type acceptance stickers on transceivers capable of transmitting way beyond the bands assigned to the amateur radio service.
I have breaking news for you:
Neither a modded Part 97 accepted amateur transceiver, nor a valid ham license
are prerequisites for jamming or otherwise harassing a licensed system.
Any number of surplus (and new) Part 90 transceivers on every band and mode
are readily available to anyone mentally deficient and determined enough to do the dirty deed.
Transceivers don't jam public service licensees. Crazy people do.
cousinkix1953
"The FCC created this problem; when they put Part 97 type acceptance stickers on transceivers capable of transmitting way beyond the bands assigned to the amateur radio service." Where did you come up with that notion? I have yet to see a transmitter certified for Part 97 service capable of transmitting out of band.
Most, if not all Amateur transceivers are fully capable to receive out of band and may be modified to transmit over their receive range but that voids the certification.
And you need one of those things like a redneck needs a machinegun to hunt jack rabbits in the desert!
The 2 meter ham band = 144-148 mhz. MARS stations are operating just above and below those frequencies. None of them have a need to own radio capable of operating 10 mhz and more out-of-band. A ham I knew carried two seperate HTs for this purpose! He was a LEO too.
The same thing happened, when we started seeing a microphone screwed onto the front of a shortwave receiver. Nothing was easier than turning the YAESU FT-757 GX and GX-2 into an illegal CB radio. No jumper wires; just a switch hidden behind the front panel. CLICK, and there is your general coverage uninterrupted 10-160 meter transmitter. I had one; but cussing out the US Coast Guard, Stategic Air Comand and other government agencies on shortwave didn't appeal to me.
A moron couldn't by a ham radio easily capable of jamming the police channels before the mid 80s! Putting a YEASU FT-101 tube set on the CB band required custom made IF crystals and some knowledge about retuning a radio. So fewer people blew $500 or more on these used rigs and then spent another $100 modifying them.
In that case, I stand by my statement that the FCC created their own law enforcement headaches, by putting this stuff on the market. Meanwhile, they'll put a part 15 sticker on anything the electronics industry wants to call an AM radio. It's our fault if all we can get is a cheap piece of crap that hears nothing but static. I just finished a battle with PG&E because their dirty power lines jammed all but the last 200 khz of the band!
Build your own ham toys until Hell freezes over. Most of you guys are "appliance operators" who buy commercially produced radios and equipment which do require a type acceptance sticker on them...
djpaulino
Temecula, Riverside County CA
Whats it matter who modified the gear?..it's very simple and mod instructions are readily avaialable on the net. Unfortunately it's pretty easy to do. Anyone with half a brain cell can do it.
zz0468
In this case, it probably DOES matter. It's one thing to modify the equipment for some legitimate purpose, and another if it's used in some criminal way. Wouldn't that make the person who modified it an accessory to a crime?
And apparently, someone with half a brain did.
djpaulino
I don't know, possibly. Is it a crime to modify any type of radio? Modified ham equipment if it was even used, I don't think that is the focus of this case. Finding the source of the interference and eliminating it and prosecuting the actions of the party responsible was. Also, do we know for a fact that modified radios were used? As the article stated there were multiple radios, computer for programming , frequency lists ect seized, what could very well be commercial type accepted equipment. It's real easy to program type accepted radios too.
zz0468
No. It becomes a crime if that modified radio is used in an illegal manner.
I would imagine that the people on the receiving end of the interference would want to know who, why, and how this came about, whether or not anything can be done about it in court.
It hasn't been made clear as to whether it was commercial gear or amateur gear. It doesn't matter. While the local authorities may have no jurisdiction, it is a violation of FCC R&R to have a transmitter programmed on unauthorized frequencies (90.427 b). That rule makes no distinction as to whether it's a modified amateur radio, or a commercial radio programmed in an unauthorized way. In a widely publicized case such as this, it's not unreasonable for the FCC to step in and take some sort of action against those responsible.
This is a good example of why it's just a bad idea to program a radio that way "just in case".
zz0468
It wouldn't surprise me if the FCC does not take any action...
Neither should you be surprised if they do. As slug-like as they can be with amateur enforcement, this is not really an amateur enforcement case.
MtnBiker2005
San Diego County, California
:roll: [update:] :(
Monday, July 02, 2012
Irene Levy,KJ6CEY,arrested AGAIN-violates probation, back to jail...
San Jacinto prankster arrested again for pointing laser at fire engine
SAN JACINTO, Calif. (KABC) -- A 31-year-old San Jacinto woman was behind bars for a second time after allegedly pointing a laser at a firefighter behind the wheel of a fire engine.
Irene Levy's colorful history makes her no stranger to her community or local law enforcement. She is best known in San Jacinto for a stunt she pulled in May 2010 when she used an amateur radio to interfere with an emergency response dispatcher.
http://abclocal.go.com/kabc/story?section=news/local/inland_empire&id=8722634
http://blog.pe.com/crime-blotter/2012/07/03/san-jacinto-one-womans-vendetta-against-law-enforcement/
http://www.pe.com/local-news/rivers...-jacinto-woman-flashed-laser-deputies-say.ece
http://www.swrnn.com/2012/06/30/san...d-for-pointing-a-laser-light-at-a-fire-truck/
gewecke
Illinois
:roll: [update:] :(
San Jacinto prankster arrested again for pointing laser at fire engine | abc7.com
SAN JACINTO: One woman’s vendetta against law enforcement : Crime Blotter
SAN JACINTO: Woman flashed laser, deputies say | Breaking News | PE.com - Press-Enterprise
San Jacinto: Woman arrested for pointing a laser light at a fire truck
Is it premature to say that... The woman is a nutbag?? :twisted:
Anything with a power source should be designed to run away from this woman!
73,
n9zas
MTS2000des
5B2_BEE00 Czar
FCC asleep as usual
and why does was this turd allowed to renew her license, despite being convicted of crimes directly related to violating the Comm Act of 1934, among others, has certainly demonstrated a lack of good moral character to hold an FCC license of ANY kind, let alone one for part 97.
As of my writing this, she had nothing showing on her ULS file with the FCC, and in 2011, had no trouble letting the FCC know her new address, and I'm sure she didn't tell them about her subsequent criminal convictions involving radio use to interfere with part 90 either.
Another case of the FCC asleep at the wheel..
Keith_W7KEW
California
73,
n9zas
She is not a nutbag. She is a socially challenged gal with a warped mind. You should learn to be more political correct.
kb2vxa
Point Pleasant Beach, N.J.
Follow the paper trail. In April 2012 Mike left San Jacinto for Redlands, Irene stayed behind. Two months later they hooked up at a new address in San Jacinto, a month passes and she's in trouble again so make of it what you will.
As an aside, I can think of better things to do with pocket lasers like put your noodle to work and open your own private ham band with a friend in town.
I thought this thread died but...
I don't believe it!
There she goes again!
She's tidied up, and I can't find anything!
All my tubes and wires
But! - it's poetry in motion
And when she turned her eyes to me
As deep as any ocean
As sweet as any harmony
Mmm - but she blinded me with lasers
"She blinded me with - with lasers!"
DPD1
She certainly isn't the first to do stuff like this and won't be the last. But the odd part is that she really bucks the typical description. A young female is quite unusual. But I would be interested to hear the theories from a Doctor about why some people do this whole... radio jamming, emergency services obsession... thing.
