Henderson County Upgrade Status
btlacer
KI4SJU/ Fire Captain/ EMTFR
Henderson, Ky
Here is the tower for the backup dispatch center. This will be the primary dispatch location while they upgrade the central dispatch center located at the Police Dept. I am aproximity 2 blocks from this dispatch location.
eaf1956
Evansville, IN
Ok so what is the CC and other info for this supposed system? Surely being so close you should get a signal.
btlacer
Henderson, Ky
I have not heard anything. I have my 668 searching the 700 mhz band and have not heard anything yet. If you all have a better idea of how to search for the cc please let me know.
fao110
Has anyone found any license information besides the ones for the microwave side?
fao110
The new system is not up yet they will not be testing until after the first of the year.
btlacer
Henderson, Ky
Yea I have had signal stalker running everyday searching the public service 700 mhz and not heard a thing yet. Been told they still don't have all the radios installed in the vehicles yet.
KD4YGG
FCC callsign WQYP892 granted on 05-Dec-2016.
Database has been updated!!!
dakota91
Simulcast monitoring
For those who lack experience monitoring a simulcast system, it's usually more difficult than just buying a new scanner capable of Phase II decoding. Depending on where you live, you may get excellent decoding or terrible decoding. Since all towers will be broadcasting on the same frequency, the signal will reach your scanner antenna at slightly different times. Unfortunately, Uniden, GRE, and Whistler scanner lack the ability to do the error correction necessary to successfully decode the voice channels. Depending on where you live, you may be able to point it toward a specific tower, but even that may not work. Also, I don't know how this new system will work, but most simulcast systems use radio affiliation, so only towers that have an affiliated radio associated with it will broadcast the conversation. If that's the case with Henderson then it's likely only the tower in the city limits will be broadcasting city conversations, in which a Phase II scanner may work fine with the stock antenna.
For those that are looking to buy a new Phase II scanner, you should seriously consider using a program called "OP-25", which runs under Ubuntu 14.04. The software and Ubuntu is free so the only thing you would need are:
1. Computer (Intel I5 or AMD A-8)
2. software defined radio stick (https://www.amazon.com/NooElec-NESD...2-spons&keywords=software+defined+radio&psc=1)
3. an adapter to convert from your current antenna connector to an SMA connector
4. the instructions (http://forums.radioreference.com/so...rtualbox-project-run-op25-windows-7-a-39.html
5. external computer speakers.
If you already have a computer you're not using a lot, you can use it to monitor a digital trunked system for less than $30. If you don't have a spare computer, if you read earlier threads in the forum message you will find instructions for installing the Ubuntu and OP-25 on a bootable USB flash drive so your computer can be a scanner when it isn't being used for anything else (or you can install Ubuntu on the same drive as Windows and boot up to whichever OS you want to use).
Where I live now (I grew up in Henderson), we have a six-site simulcast system and I have no path to point a yagi antenna at only one tower. I use OP-25 and an omni-directional antenna and I get perfect voice decodes and reception while my GRE scanners are worthless trying to monitor this system. OP-25 used to very difficult to install and run, but several individuals have written easy step-by-step instructions. You now no longer need to know Linux to make this work.
trido
Southern In
plus i noticed today the HEND pd Cars still dont have 800 ant installed.
QUOTE=eaf1956;2679010]Wow the Database is updated and lo and behold they don't even have a CC active yet. Go Figure..[/QUOTE]
kd4bas
Monitoring, Hanging Out, & --mn-@v@-mn-- you.
Morganfield, (Union Co) KY
Here's the long awaited FCC data. Happy listening when live :lol:
HENDERSON, CITY OF
1990 BARRET COURT
HENDERSON KY 42420
Callsign: WQYP892
Radio Service: SY-Trunked Public Safety 700 MHz
APPLICANT IS A GOVERNMENTAL ENTITY AND WILL USE RADIOS FOR OFFICIAL GO
VERMENTAL ACTIVITIES AND TO PROMOTE SAFETY.
Action: ISSUED
Area of Operation
1 FIXED 374448.2N 087251.5W HENDERSON HENDERSON KY
2 FIXED 374622.4N 087445.3W HENDERSON HENDERSON KY
3 FIXED 374858.7N 873537.1W HENDERSON HENDERSON KY
4 MOBILE HENDERSON KY
5 UNKNOWN 6 HENDERSON KY
Pwr ERP # of # of (A)nalog
Ref Class Freq Out Out Units Pagers (D)igital (X)Unknwn
1 FB2 769.28125 100 047 1 0 9K80D7W (D)
1 FB2 769.53125 100 047 1 0 9K80D7W (D)
1 FB2 769.85625 100 047 1 0 9K80D7W (D)
1 FB2 770.10625 100 047 1 0 9K80D7W (D)
1 FB2 771.15625 100 047 1 0 9K80D7W (D)
2 FB2 769.28125 100 047 1 0 9K80D7W (D)
2 FB2 769.53125 100 047 1 0 9K80D7W (D)
2 FB2 769.85625 100 047 1 0 9K80D7W (D)
2 FB2 770.10625 100 047 1 0 9K80D7W (D)
2 FB2 771.15625 100 047 1 0 9K80D7W (D)
3 FB2 769.28125 100 047 1 0 9K80D7W (D)
3 FB2 769.53125 100 047 1 0 9K80D7W (D)
3 FB2 769.85625 100 047 1 0 9K80D7W (D)
3 FB2 770.10625 100 047 1 0 9K80D7W (D)
3 FB2 771.15625 100 047 1 0 9K80D7W (D)
4 MO 769.28125 003 002 450 0 8K10F1W (D),8K10F1W (D)
4 MO 769.28125 035 026 325 0 8K10F1W (D),8K10F1W (D)
4 MO 769.53125 035 026 325 0 8K10F1W (D),8K10F1W (D)
4 MO 769.53125 003 002 450 0 8K10F1W (D),8K10F1W (D)
4 MO 769.85625 035 026 325 0 8K10F1W (D),8K10F1W (D)
4 MO 769.85625 003 002 450 0 8K10F1W (D),8K10F1W (D)
4 MO 770.10625 003 002 450 0 8K10F1W (D),8K10F1W (D)
4 MO 770.10625 035 026 325 0 8K10F1W (D),8K10F1W (D)
4 MO 771.15625 035 026 325 0 8K10F1W (D),8K10F1W (D)
4 MO 771.15625 003 002 450 0 8K10F1W (D),8K10F1W (D)
4 MO 799.28125 035 026 325 0 8K10F1W (D),8K10F1W (D)
4 MO 799.28125 003 002 450 0 8K10F1W (D),8K10F1W (D)
4 MO 799.53125 003 002 450 0 8K10F1W (D),8K10F1W (D)
4 MO 799.53125 035 026 325 0 8K10F1W (D),8K10F1W (D)
4 MO 799.85625 035 026 325 0 8K10F1W (D),8K10F1W (D)
4 MO 799.85625 003 002 450 0 8K10F1W (D),8K10F1W (D)
4 MO 800.10625 035 026 325 0 8K10F1W (D),8K10F1W (D)
4 MO 800.10625 003 002 450 0 8K10F1W (D),8K10F1W (D)
4 MO 801.15625 003 002 450 0 8K10F1W (D),8K10F1W (D)
4 MO 801.15625 035 026 325 0 8K10F1W (D),8K10F1W (D)
5 FX1 799.28125 035 047 25 0 8K10F1W (D)
5 FX1 799.53125 035 047 25 0 8K10F1W (D)
5 FX1 799.85625 035 047 25 0 8K10F1W (D)
5 FX1 800.10625 035 047 25 0 8K10F1W (D)
5 FX1 801.15625 035 047 25 0 8K10F1W (D)
trido
Southern In
hope not fullpower
I had to walk out side our store and get ONE bar on unication G5 pager.
dixie729
Daviess Co., KY
Talked to one of the technicians last week. Said the project was put on hold. Didn't say for how long
Sent from my XT1097
