Henderson NV PD Control Channels
FERRER53
I am programming a radio to monitor Henderson PD Nevada. . I noticed on this site, the control channel appears to be a non- reband frequency. Does anybody have any updated control channels information or recommendations?
73'S
737mech
Clark County, NV.
SNACC Henderson PD
What radio are you trying to program? Specifically what are you seeing non- rebanded?
FERRER53
Henderson PD Nevada
If you look on the Lake Las Vegas Henderson site, the control channel appears to be in the 86 + in stead of the 853 range. I just wanted to confirm that this is correct and working?
br0adband
Springfield MO
The current info shows:
011 (B) Lake Las Vegas - Henderson Clark 866.27500 866.77500 867.05000 867.80000c 868.95000
So I'm guessing he's wondering why those frequencies aren't necessarily grouped into the 851-861 MHz range where they typically could/should/would be. Upon checking the FCC database, they are listed on license WQIY647 which shows it's expired since 2009 so, either the info at the FCC database is incorrect or perhaps the info provided for the RR database was simply inaccurate to begin with.
Hooligan
Clark County, Nevada
Garbage In, Garbage Out. Despite tooling around Henderson often & once having the alleged Lake Las Vegas RR data programmed into my radios, they never stopped on any of the Lake Las Vegas system channels, it's always been the Black Mountain (Arden Peak) SNACC site.
FERRER53
Henderson PD NV TRS
Thanks for the information. Do you know what the connect tone is? I have anXTS3000 I have set up for passive scanning .
bfperez
Try subtracting 15mhz from those listed Lake LV channels.
FERRER53
I use an XTS3000 in passive mode scanning. A connect tone is required when setting up the trunking system.
Thanks for the response
