prcguy
With all the high gain repeater type antennas I have for every band, the antenna system I built for my wide band Icom R-8600 is a dual Discone system with one Discone covering roughly 100 to 512Mhz and the other covering 700MHz through about 2.4GHz. Its really hard to find a diplexer to combine these frequencies and I've bought a few over the years but they are really expensive new and don't come up used on Ebay very often. In fact I didn't use one on my dual Discone system simply because the diplexer was too valuable to leave up on the tower.
I recently found another diplexer on Ebay that advertises 20 to 508MHz on one port and 518 to 1300Mhz on the other port, nearly perfect for my needs and its only $35 with shipping from Israel. My Ebay diplexer arrived today and it was on the network analyzer about 30 seconds later. Its got very low loss from 20MHz to about 500MHz then it starts rolling off where it has about 6dB loss at 512Mhz. On the other port it works fine from about 520Mhz to over 2GHz.
For those that don't have much T band activity in your area this would be an excellent and cheap way to combine a lower frequency Discone to cover roughly the 100MHz through 500MHz, then a 700/800MHz gain type antenna or a small Discone that covers 500MHz and up. These K&L diplexers probably ran in the $500 to $1k range new. The Ebay seller has several more of these and it takes a few weeks to get it but for $35 its worth the wait.
K&L 5IZ10-20/X1300-0/0 Diplexer 518-1300MHz 20-508MHz | eBay
Our team will be here to support you all the way from purchasing to the arrival of your item. An item that does not function as intended and is not fully operational. For parts or not working. An item that has been used previously.
www.ebay.com
