Hernando County Fire
kd4efm
EL98 Florida
I haven't heard them in the last 4 years I have been in and out of there, most of it is on the TRS. Which will be going p25p2 and full encryption.
scannersnstuff
I can confirm that all Hernando public safety is on the trs. There are some seperate talkgroup's for Brooksville fire. I have not heard them there though.
kd4efm does seem to know what he is talking about. I have seen news account's of Hernando going to the new p25 system. The buildout will supposedly take up to 2 year's. I hope this is the case, because I have so little to listen to, I do not have any hard proof that the system will be encrypted. Based on the trending of most public safety here, it will be.
kd4efm
Pimascanman
Marana,AZ
kd4efm
Brooksville Fire is dispatched by HCFES, they are not on a separate talk group, there is even a medic rescue stationed at Brooksville station 61 which is HCFES M10. just FYI.
18bravo
Lake Whales
Are we sure the data in the database is correct. I’m getting several decimal to Hex errors for talkgroups.
zlandmedia
not that florida man
Hillsborough County, FL
Looks to be a bug with RRDB 2.0. I downloaded the CSV (premium subs only) for the system and the correct hexadecimals are showing there.
In the interim, I would suggest using this calculator to convert the decimal format (which those numbers are correct) to hex.
18bravo
Lake Whales
I appreciate it. I’m not getting any transmission on the system it’s silent. Not sure what’s going.
18bravo
Lake Whales
Something is still screwy with the numbers
18bravo
Lake Whales
If you need the hex values use the calculator I linked to above. The decimal numbers are correct.
there are decimals wrong for sure.
Talkgroup 44964 the hex c200 per calculator which you can not enter in the radio. There are several decimals that are like this.
zlandmedia
Well, does your radio support monitoring of Motorola Smartnet Type II systems? The only thing I can think of is that the system is incompatible with your radio if it's not letting you enter the hexadecimal values, which are correct as well as the decimal values on the talkgroups.
I monitored the system on my SDS100 last week and it's alive and well.
18bravo
Lake Whales
I would think so it’s a APX8000HXE.
If you drop the hex c20 it changes the decimal. Hex can only be 3 digits.
18bravo
Lake Whales
