High Band Genesis Radios Programming
KA0XR
Minnesota
I have the hex edited RSS and hardware to program low band Genesis Radios, but If I come across an old VHF Genesis radio would the same RSS work on high band? Or would I need to somehow find a high band-specific RSS?
Also, are high band Genesis radios with the 146-162 MHz band split able to be programmed up to receive NOAA Weather Radio or down to 144 MHz?
Thanks in advance for any insight.
MTS2000des
5B2_BEE00 Czar
When you say "Genesis" radios, there were:
HT600/P200 (same family of RSS) and controllers
MT1000 (uses different RSS) and different controllers
As far as bandsplits for VHF there were:
136-150.8
146-162
157-174
The 136-150.8 will do the ham band natively. Doubt the VCO will lock on 162MHz. These radios aren't very wideband.
The 146-162 needed your hex modification, they should RX NOAA just fine
The 157-174 is useless on anything below about 153MHz.
gary123
You can try the old shift key method. This worked on the maxtrac/radius lines. To enter in 162.550 type !^@.%%)). Hold the shift key while entering in the number characters, release for the decimal point.
The only other option is to locate the band limits in the CPS and hex edit.
KA0XR
Minnesota
136-150.8
146-162
157-174
The RSS versions I have on an old computer is used to program two lowband MT1000's (one for 10 meters and one that goes up to 52 MHz) and a single lowband P200 that I have on 6 meters. Since I've never had a high band Genesis would I need a different RSS file (HT600/P200 or MT1000) to program a high band radio?
Also, are you saying that I would need to hex edit the RSS to do both the NOAA channels and to go below 146 on a 146-162 band split radio?
gary123
On the 146-162. you should be good to 162.995. but I would just try the keyboard shift hack first. editing the RDD requires a little knowledge on hex editing. Also you may have to dig to find the band limit math. The limits may be direct hex values or they may be in some other format such as Intel long (CPS for sure)
kf8yk
The RSS for P200 low band (HVN9794) only works with low band radios, you need HVN9262 for VHF high & UHF P200's. The HT600 never had a low band version.
RSS RVN4017 covers all bands for the MT1000.
KA0XR
Minnesota
OK thanks for clarifying that I'll need a specific high-band RSS. Interesting that the HT600 never came in a lowband version while the later Genesis models did.
