Take it off the rack altogether.
A
BREEDLOVE Antenna Mount (permanent) is how to do it. Cab roof. 4” Puck or CB Ball for a
Tall antenna or a 4” NMO mount for a
Short antenna.
A VERY tall antenna in a stake bed pocket is another route.
I use 14’ on a semi as total antenna height. And AT LEAST a 5’ antenna to get there. I’ve a big puck mount to go on my Ram near roof center. And a whole slew of antennas of different lengths to cover both town & country.
You can try adding RF Bonds with what you have:
Mobile Install
but it won’t ever be as good as a quality roof-mounted antenna.
IMO, there’s not much point to having a CB Radio if the antenna (system) isn’t up to the job. That’s what matters.
A cheap radio with a great antenna system will walk all over a $$$$ radio with a total crap antenna system (what you have). It’s not even close.
Start from a fresh perspective. Installing a clean DC Power System and a quality Antenna System are not
that hard, even if the subject is new.
It will need some reading and some list-making. Supply and maybe some tools. But you won’t have to re-invent anything. It’s a
known set of problems to solve.
The pains I’ve gone to with modern semi tractors (big ones) you won’t have to get involved with. And you’ll have something better
if you do it right.
I want (and work towards)
always getting the most I possibly can from a radio. The radio
must have clean 12V and
best antenna mount + coax installed if the rest of my gear is to pull those faintest radio signals into clarity.
Mobile CB is harder than it was in 1978. So’s everything else.
But when it comes to on-road problems, there is just no substitute for having heard that
far earlier than others. Choices. Some things known only two miles ahead can’t be acted upon. At twelve miles — or farther — they can.
Upgrading your truck with a permanent mount antenna
is that road.
Hear, and be heard.
