Grondoline
- Joined
- Dec 19, 2002
- Messages
- 49
Does anyone know if a Uniden BC23A EXTERNAL SPEAKER will work with the Home Patrol II? I have plugged every speaker in my vast collection into the headphone jack and there all vey low or no volume.
It should. It's an amplified speaker. The audio output at the headphone jacks on Uniden scanners is very low. Sufficient to drive a headphone, but not enough to generate usable volume for an unamplified speaker.Does anyone know if a Uniden BC23A EXTERNAL SPEAKER will work with the Home Patrol II? I have plugged every speaker in my vast collection into the headphone jack and there all vey low or no volume.
I recommend you use Powered speakersDoes anyone know if a Uniden BC23A EXTERNAL SPEAKER will work with the Home Patrol II? I have plugged every speaker in my vast collection into the headphone jack and there all vey low or no volume.
-I have plugged every speaker in my vast collection into the headphone jack and there all vey low or no volume.
Thanks... and validation that it works... if you plug in just the power the red light should always stay on?To bad no Radio Shack around anymore...
It's a standard 1/4 watt 5% tolerance metal film resistor from what the pict shows...
Just standard electrical sleeving or shrink tubing is fine...
