homemade antenna
godskidz
Bartonsville Pa.
Hi all.
I am going to buy a radio shack antenna 20-176 but for now I
have to make one out of just wire.
What would be a crude way to do this?
GOD BLESS
Medford, OR
Quick easy one I used it get a matching transformer from Radio shack, such as this one ( http://www.radioshack.com/product/i...mer&kw=matching+transformer&parentPage=search) or the make a 4 port one that will work. Then use an antenna calculator to determine the proper lengths for tyhe wire elements ( http://www.crompton.com/wa3dsp/hamradio/antcalc.html) best to use the half wave number. Cut the wire to the lengths you need, connect it to the matching transformer, then run some RG-6 (or equivelent) to you scanner.
I use a similar setup using 4 elements and it works great.
Just my $.02USD
prcguy
A “nest of dipoles” can certainly make a useable antenna, but why would you recommend connecting a bunch of 70 something ohm dipoles to a 300 ohm transformer?
prcguy
Just my $.02USD
Medford, OR
prcguy
I think you may be misunderstanding due to bad terminology on my part. Basicly it is an OCFD, with a 4 input matching transformer (Balun) rather than the normal 2 input.
Looks just like that, but with 4 screw terminals ( 2 VHF and 2 UHF).
JohnJRambo
Traverse City, MI
k9rzz said:
A simple ground plane built around a SO-239 coax connector is my fave:
http://www.hamuniverse.com/2metergp.html
You could build it as described and it will work well on a wide range of frequencies.
John K9RZZ
Yeah, what John said. Back in the early 70's, we built these ground planes out of metal coat hangers for 2 meter use. They work good and they are cheap. JJR
N4JNW
Irvine, KY
What would you say if I told you you could make an antenna out of a simple peice of coax? Yep- That's right, go to RadioShack, or find a old peice of RG-8 or RG-58 coax laying around.
Strip about 15" off the end, leaving only the bare center conductor exposed, with NO wire braid shield around it.
Tape the dude up and hook it to your scanner!
AuntBee09
WA
i was able to wrap tin foil around a really crappy antenna i had and it made a big difference. i had to slide it up and down to the right point tho.
