What is the "debug" folder all about anyway...?
Do not worry about it for now, will explain later.
As a test I rolled my firmware back to 2.04.01 to rule out hardware issues since I was going to be driving through areas with simulcast sites that didn't seem to get along with the 2.06.08 beta and the scanner was full with traffic. Two days later I was headed back to the same area so I upgraded to the latest beta and had the same issues - Little to no traffic and talkgroups displaying but no producing audio.
So do you think your situation was no audio what so ever where the scanner actually was stopping on an active and decoded TG and the audio section had not unmuted or the scanner stopping on a TG allowcation, but was not able to decode the voice traffic?
It sits on talkgroups longer than the delay so it's like the control channel says there's traffic but the scanner isn't decoding it. And before someone asks, no it was not an encrypted talkgroup![]()
Are you planning on sending into repair with this problem? Sounds like it could be a cold solder joint or bad component.So to update what is going on with my specific HP-1 and the latest Firmware version 2.06.08.
Having some intermittent issues where the scanner has been going quiet like it had with earlier versions of firmware.
Scanner seems to stop often, display will brighten up, but there will be no audio.
Also the going deaf/quiet after a few minutes.
The ONLY thing that has changed is the ambient temperature have dropped/gotten cooler.
A few weeks ago I was dealing with ambient temps up to 103F, had driving 2500 miles with the radio in a RAM windshield mount with the sun beating on the radio and at times external power connected. Radio was very warm to handle at times.
Now I have temps in the 60F range and if I leave the scanner in the car overnight it seems the ambient temps are impacting the scanners performance.
This issue is not 100% consistent, but temperature does appear to impact the trunking performance on at least my radio, might be part of what is going on with some of the others that are not seeing consistent performance with a giving Firmware version?
Be curious if others may have noticed this issue with temperature?
The only issue I've seen here in Ohio with ambiant temperature was last winter when we hit -40F and I left the HP1 in my truck overnight. The unit didn't want to fire up in the morning unit it warmed up.
J
