Astrogoth13
I was looking here:
VK16E Module Gmouse GPS Module SIRF3 Chip GPS Module w Ceramic Antenna TTL Level | eBay
I wonder if we could bypass the serial port on the back of an HP scanner and mount one of these boards inside to provide GPS location data all the time? 5 wires, two for power, one ground and two data. This board uses the same chipset as the Uniden GPS does. All we need to know is what pins on the back of the serial port do we solder the two data wires to.
Ideas?
Ideas?
