I would connect each antenna to its own receiver/scanner. Then make notes on what antenna works best for a particular system or frequency that are more difficult or impossible to receive from the other antenna/receiver and then divide up the systems and frequencies between receivers to get the best reception. I use 6 different antennas split up between different scanners and receivers.
If you have a multicoupler and need to feed several scanners then use that multicoupler with the antenna where it makes most use to those other receivers. You can do your own multicoupler using a $30 preamplifier based on a PG103+ amplifier and then use a $10 CATV splitter and a suitable $5 attenuator to give a final gain of 3-6dB at the splitters output and it will perform better than a Stridsberg.
I once had two antennas with their coaxes connected together using a T-connector and I had several small coaxes of different length like 5-10-20 inches, that would be 1/8 and 1/4 wavelengths of a frequency, and inserted them between T-connector and one coax to make it longer and depending of the direction of the source and its frequency I could then receive that signal stronger when the two antennas where more or less in phase with each other than trying to receive using just one antenna. Another direction or frequency or using the wrong coax length would make the signal worse than using a single antenna. Any strong signal could still be received even using the wrong phase but a single, very noisy, signal could be made to be received stronger.
There are QRM eliminator boxes that have phase controllers to cancel out interference by using two antennas but can equally well be used to instead add two signals in phase. Then that box would simulate different length of coax to one antenna. But most of them have components values that make them suitable only for shortwave frequencies.
/Ubbe
