ok so just to clarify, if I already have EZ SCAN on my computer which I use with my 2 PSR 800s then I can just copy my configuration to the new PRO 668? Just so there's no confusion I'm not talking about doing anyffirmware upgrades.
I have the PSR-800 and the Pro-668. I have both the both the EZSCAN software and the ISCAN software. I have been using the PSR-800 for a few years. I went into the documents folder under the EZSCAN and copied the CDAT folder and then copied it into the ISCAN folder so I didn't have to redo all of my programming from scratch on the Pro-668. The only issue I had after sending the programming to the PRO-668 is my signal strength on the Pro-668 was very low from some setting that was copied over from the PSR-800 settings in the CDAT folder. I did a reset to factory settings and then went back into the settings and set the backlight, priority, keypad beep and a few others and everything is working great the next time I programmed the scanner. You can also reset to factory settings on the scanner it's self too and then just to into settings menu and set everything the way you want it.
Mike
Thank you for the quick reply... I'm heading out work...I'll get all that info out tonight....
I'm in Wall Township N.J. ...I' m looking to monitor Asbury Park, N. J. and Ocean Township N.J..... (both in Monmouth County)
Most off our neighboring towns in OCEAN County have gone to P-25 as well...
Best Regards.... Back to you later
J.F.
Hi Guys...I've been wrestling with programming this pro-668 for about a week...Any p-25 frequencies are coming thru sounding like a busy signal on the phone.. what am i doing wrong...thanks Jim by the beach
Figured it out. It's easier, and I use that loosely, from the scanner. That software is terrible.
